160 degree thermostat
What's your answer to these experts below?
From the Dewitt's Radiator web-site:
http://www.dewitts.com/download/cooling.pdf
...is this direct quote:
"Furthermore, 160º is too
cold; OEM testing has proven that the rate
of cylinder bore and piston-ring wear at
160º is double the wear rate at 180º, and
a coolant temperature of 160º won’t let the
oil in the pan get hot enough to boil off
condensed moisture and blow-by contaminants,
which then remain in suspension
and accelerate the formation of acidic and sludge. 160º thermostats were specified in
the 1930s for the old alcohol-based antifreezes,
which would boil off and evaporate
at 185º; there’s no other reason for
them."
From this site:
http://www.johnnysradiatorshop.com/files/32341017.doc
...is this quote:
"If the thermostat needs to be replaced, install one with the same temperature rating as the original. Most cars and light trucks since 1971 require thermostats with 192 or 195-degree ratings. Using a cooler thermostat (160 or 180 degree) can increase fuel and oil consumption, ring wear and emissions."
From this site:
http://www.carnut.com/ramblin/cool3.html
...is this quote:
"Years of research show use of 160 degree thermostats is way too low to be considered for performance or engine longevity. As the chart above illustrates, engine wear increased by DOUBLE at 160, than at 185 degrees."
From this book:
http://books.google.com/books?id=lZ5...esult&resnum=8
...is this quote:
"Don't let the would-be automotive expert talk you into taking out the thermostat. If there was a way for Chevy's engineers to ensure that the engine got fast warm-ups to avoid sludge and acid formations - and therefore engine wear- other than controlling the water temperature, you can be sure they would do it in a minute...The hotter the cylinder walls, the less friction loss."
From this site:
http://www.lincolnvscadillac.com/tec...tems/page2.htm
...is this quote:
"To help alleviate a hot-running engine, some think that removing the thermostat and allowing full-time, unrestricted flow of coolant that the engine will run cooler. If your engine is running hot and overheating, assuming that the rest of the cooling system is in good working order and has the capacity to keep your high-dollar, big-horse motor cool, then removing the thermostat is NEVER the correct thing to do."
And from this site:
http://auto.howstuffworks.com/cooling-system1.htm
...is this quote:
"Inside your car's engine, fuel is constantly burning. A lot of the heat from this combustion goes right out the exhaust system, but some of it soaks into the engine, heating it up. The engine runs best when its coolant is about 200 degrees Fahrenheit (93 degrees Celsius). At this temperature:
* The combustion chamber is hot enough to completely vaporize the fuel, providing better combustion and reducing emissions.
* The oil used to lubricate the engine has a lower viscosity (it is thinner), so the engine parts move more freely and the engine wastes less power moving its own components around.
* Metal parts wear less."
If you wish, I could post another 100 links with similar quotes.
Again, please explain why the experts above have it all wrong.
And then, your turn. Show us a credible source(s) that recommends that we swap to a 160 degree thermostat for street performance. Here's a good place to start: www.google.com
...is this quote:
...is this quote:
...is this quote:
...is this quote:
...is this quote:
BTW, I love your avatar!
PK
From the Lingenfelter web site regarding their 160 degree thermostat:
"Reducing coolant temperature will help produce more horsepower and improve your performance and drivability. The thermostat is an easy to install component and requires no modifications."
SLP (who make the Firehawk for Pontiac)?
From the SLP (Street Legal Performance) web site regarding one of their 160 degree thermostats:
"This low-temp thermostat can dramatically reduce the operating temperature of your LS1 or LS2, increasing power, ensuring consistent performance, and extending engine-component longevity. This OEM-quality piece comes with complete instructions and all hardware required for a quick and easy installation."
You don't seem to be reading my posts very well, but I'll state it again since it is a slow day: I go with the manufacturers recommended thermostat unless I have some specific reason not to. Once the reason is resolved, I have gone back to the stock stat. You want a recommendation? I recommend everyone do the same. Happy now?
But thanks, finally. We might see a supporting doc to counter the well written and credible recommendations against the use of a 160* stat.
If Lingenfelter didn't believe that a 160 degree thermostat offered a performance advantage over a 180 degree thermostat, would he offer it on his web site and note that it provided an advantage?
Just because he sells the product doesn't make him any less reputable than those who don't.
http://www.lingenfelter.com/mm5/merc...Category_Code=
i have run a 160 stat in winter and my car runs at 160
i have run a 160 stat in summer and my car runs at 170-175
i have run a 185 stat in winter car runs at 175-185
i have run a 185 stat in summer car runs at 190
so in winter i run a 185 stat and in summer the 160 that way i dont have to turn on the thermo fan so much. i think vapourisation will occur at all these temps and the difference is insignificant .
i do have one point but if i start my car and give it a flogging when its only at 140 it will have no HP at all. who said low engine temps give good HP? same thing with my gf,s toyota and same thing with my mazda. could all 3 cars be mutants?
...is your support for the recommendation for a 160 degree thermostat in a Gen I engine, go back to the well: www.google.com
Gen II engines have reverse flow cooling and the stat regulates cool water from the radiator; not hot water that's already passed through the engine.
Also, in a reverse flow cooling system, the heads are cooled first then lower engine is cooled last meaning the cylinder walls stay warm (reduced friction), and the oil remains at temps high enough to cook out the wastes.
But at least you're working to support your opinion with documentation; something that's missing from the "160* is better arguement" so far.
You're ony looking at the one thermostat that I provided the link to. They have others for standard flow-type engines also.
If the coolant exits the engine at a 160 degrees instead of 180 or 195 degrees it is bound to lower the operating temp of the engine.
It is a system designed to maintain a particular operating temp. The radiator doesn't do it's job until the thermostat does it's job.
Once the operating temperature drops below the thermostats temperature rating the thermostat closes and the coolant circulates in the engine again in order to maintain that goal of 160, 180 or 195.
So, the thermostat doesn't just open up and then it's done, it opens and closes according to the temperature of the coolant.
cc
cc
I have a 502 with a 180 thermostat. My temps go to 180 and stays there.
But that aside there is a lot of good info here, even though I can get a good laugh now and then.
