Timing
Old Feb 3, 2002 | 09:55 PM
Ben Taylor's Avatar
Ben Taylor
Default Timing
I just put my distributer back in, and when I have my harmonic balancer lined up with my timing chain cover my distributer is pointing at the spot for the wire to cylinder 8, not 1, I did take my fan off with the distributer out, and may have turned the engine slightly at that time, how do I get this lined up again?
Old Feb 3, 2002 | 10:35 PM
Pete79L82's Avatar
Pete79L82
Default Re: Timing (Ben Taylor)
Lift the distributor up and turn it counterclockwise one or two teeth until it lines up with #1 cylinder. You can either use a long screwdriverto turn the oilpump shaft or turn the motor over slowly until the distributor falls in place.
Old Feb 4, 2002 | 02:04 AM
Ben Taylor's Avatar
Ben Taylor
Default Re: Timing (Pete79L82)
Thanks, I thought it would be something like that, I just didn't want to screw it up anymore before asking.
To Timing
