Wheel Help please
Old Feb 3, 2002 | 10:36 PM
81ZZ4's Avatar
81ZZ4
Default Wheel Help please
I see the topic of group purchase on the tourquer wheels...too bad all the same size...thanks for trying though :cheers:
What is the widest I can squeeze in my wheel wells on my 81? Looks like you all mostly like the 17 inch...any particular reason?
I have 255 60 15 now...what it came with from the factory.
Wanna get them now...they look great on the pics I have seen some time back.
Thanks :yesnod:
Old Feb 4, 2002 | 02:06 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Wheel Help please (81ZZ4)
i'm not running the torq thrusts on my '81 but i am running 17s, they're factory wheels from a '93 base coupe. as near as i can figure about the widest you can reasonably fit on an '81 would be 8.5-9" width with about a 275mm tire (if you want to stay in the wheel well). the 9.5s on the back of mine have 285s and just barely stick out. it's so close, i had to put a straight edge across the tire to see how far and it was about a 1/8-1/4" past the well.
Old Feb 4, 2002 | 11:00 AM
81ZZ4's Avatar
81ZZ4
Default Re: Wheel Help please (clutchdust)
Thanks....
Anyone in here who has them on their C3...I remember something to do with 4 or 5 inch back set of rims and spacers.
Old Feb 4, 2002 | 12:36 PM
Stingy74's Avatar
Stingy74
I've got 9.5" wheels on all four corners of my car. They are 5" backspace, the least amount Centerline makes in a 9.5" wheel. I used one 3/8 spacer all the way around to clear the calipers in the back and the tie rods in the front. They don't stick out at all.
Old Feb 4, 2002 | 01:22 PM
VetteBoy1979's Avatar
VetteBoy1979
CI 3-4-8 Veteran
St. Jude Donor '07-'09-'12
Where is the post on the GP on the Torquer wheels? :confused:
To Wheel Help please
