Intake leak
Old May 7, 2009 | 08:57 AM
Blown 79's Avatar
Blown 79
Default Intake leak
I'm about to pull my hair out. I'm running a small block with a 671 blower and can't seem to get the rear intake to seal. I tried the cork gasket first, blew it out, next I used red atv, and blew it out. It doesn't have any blowby so I assume its not a crankcase pressure problem. I'm getting tired of pulling the blower and intake any help would be apperciated.
Old May 7, 2009 | 10:39 AM
Vette79C3's Avatar
Vette79C3
Funny, I have the same problem. I used a product called, "The Right Stuff" which does very well. Couldn't hurt to try this: http://www.permatex.com/products/Aut...sket_Maker.htm
Old May 8, 2009 | 08:48 AM
Blown 79's Avatar
Blown 79
Thanks, I'll give it a try.
Old May 8, 2009 | 08:54 AM
midyearvette's Avatar
midyearvette
more than likely, you probably dont have enough clearance at the china walls to hold sealant from squeezing out for a seal......try fitting the intake at first with no rail and intake gaskets to see....should have a good 1/8 inch minimum...if not..thicker intake gaskets or mill the intake....good luck....
Old May 8, 2009 | 10:55 AM
7T1vette's Avatar
7T1vette
Remove all intake gaskets/sealant, then place the 'bare' intake manifold on the block and use shim gauge to see how much clearance you have at all joints where gaskets/sealant is to be used. As mentioned above, you probably have too much clearance at one or more joints. If so, you need to use a 'hard' gasket filler to take up most of that gap and thin layer of sealant to make the joint seal. Don't forget to calculate in how much compression you will get with the gaskets and bolt torque that you will be using.
An alternative approach is to install just the cork 'side' gaskets, but no gaskets/sealant at the ends; then bolt up the intake with full bolt torque. Then measure the clearance at the ends with the shim gauge. Select the gasket thickness for the end pieces so that [under compression] all gasketing will be tight.
Old May 14, 2009 | 11:47 AM
Blown 79's Avatar
Blown 79
After pulling the intake and dry fitting I discovered the gap was too wide so I did as you suggested using a hard gasket filler and then a silicone seal and it seems to be working fine. Thanks for the help. You guys are great.
Old May 14, 2009 | 12:30 PM
7T1vette's Avatar
7T1vette
Glad you found the problem. Either the block or heads [or both] have probably been milled in the past and the 'valley' relationship to each other has changed.
To Intake leak
