Fastest 1/4 mile
Now if they both had the same torque it would be closer but I would still give the edge to the 383 because of the torque curve, the 355's torque curve wouldn't be as flat even though the peak torque was the same. You are looking for power through the RPM range in each gear
my 2 cents worth....
But lets keep to the original posters question regarding drag race performance....
Performance in a drag race has nothing to do with street manners.
A 355 putting out 425 hp will need good heads and bigger cam and will require more rpm to achieve the goal... lets say 6500 rpm for peak power.
425hp in a 383 is easily achived with around 5000~5500 rpm.
That being said, whilst the torque of a 383 might be higher at lower rpm, you will need to change to next gear to sustain good accelleration.
A smaller capacity motor which revs higher, will outperform the bigger motor, as the advantage of gearing will provide a better average torque over the entire 1/4 mile.
Seen it happen all too often.
Seen plenty of 425hp big blocks that get whooped by 425hp small block mice
Same scenario with a 383 vs 355.
Whichever motor offers the highest torque in the higher rpm range will have an advantage due to gearing.
Yes, performance is all about producing torque.... but the higher the rpm at which it is produced, the quicker you will be.
Ever wondered why Formula 1 engines spin to 19000 rpm?
If somehow the 383 had some mismatched parts and made the same the torque as the 355ci then it would be up in the air as to which one would win, I would still bet on the 383ci though because the torque curve would be flatter than a "peaky" torque curve the 355ci would put out therefore more overall power under the curve
All I am saying, is if you want to get best performance for racing, you need to consider the advantages of gearing.
And that is why a higher revving motor will give the benefits, of sustaining the torque multiplication of remaining in a lower gear longer due to extended rpm, and/or combined with the advantage of running a diff ratio like 4.11's vs 3.55's.
I won't argue that a 383 will be a better street motor.
But I will say it is not necessarily going to be quicker than a properly setup car with a performance 355 over the quarter mile.
Each of these motors really requires different setups regarding gearing and torque converters to maximise performance at the strip.
Tyres play an important role obviously... Having a lot more low down torque and smoking up at the launch is NOT the quick way down the track.
If both are setup ideally, the difference will always come back on the driver's ability.
using a dyno simulator I generated some dyno results of 2 motors...
Here's the dyno results of a healthy torque monster 383 with 425 hp at 5000 rpm - a bit too optimistic, but good for this argument.
rpm hp lb-ft
2000 168 442
2500 230 484
3000 274 480
3500 319 479
4000 365 479
4500 403 470
5000 425 446
5500 424 405
6000 385 337
and here's the dyno of a 355 with 425 hp at 6000 rpm
rpm hp lb-ft
2000 136 358
2500 174 365
3000 210 367
3500 270 406
4000 323 424
4500 369 430
5000 404 424
5500 421 402
6000 425 372
6500 412 333
7000 395 296
Wow... look at all that torque difference down low... over 120 lb-ft tq.
advantage to the 383!But here's the rub.
Placing this data into a drag sim, and limiting rpm on the 383 to 5500
but allowing the 355 to rev to 6500, the results with both cars running 3.55 diff gears with a TH400 box were closer than you'd think.
In fact, with hi-performance street tyres (what ever they might be)
the 383 resulted in a 12.635 @ 114.3 mph (with lots of traction issues)
the 355 resulted in a 12.515 @ 114.2 mph
Putting on some mild race tyres made a significant difference, allowing the 383 to hook up and result in a 11.553 @ 115.4
and the 355 lost out with similar tyres with a 11.741 @ 114.6
Now if your serious about drag racing with a peaky engine that pulls 7000 rpm, you'd opt for 4.11's in the rear with a 3500 to 4000 rpm stally!
This is where the higher revving smaller cubed 355 posts an 11.496 @ 115.3 mph
Like I said, setup of the overall car will define actual performance.
Which would I prefer...
well, actually, a 383. But 425 horses isn't enough
