Halfshaft Install Problem
Old May 10, 2009 | 08:35 PM
Luke303's Avatar
Luke303
Default Halfshaft Install Problem
Installing halfshafts that had new U-joints intalled. I already have everything in the rear end bolted in; when I put the passenger side halfshaft in, it was tight and flush, no issue there. When I put the driver's side in, there was about a 1/4in gap between the trrailing arm flange and the halfshaft flange. Is this a problem?
Old May 10, 2009 | 08:39 PM
7T1vette's Avatar
7T1vette
No problem...once you bolt it up. The half-shaft is part of the rear suspension system, so the wheel might move in or out some with the shaft disassembled. Now, that doesn't mean that you might not have some other 'issue' with a trailing arm....
Old May 10, 2009 | 09:57 PM
Luke303's Avatar
Luke303
The trailing arms are newly rebuilt from V-Tech, so I hope the issue is not from them. Thanks fo the input
Old May 10, 2009 | 10:13 PM
v2racing's Avatar
v2racing
You do no that you will have to do an alignment when you are done?
Half shaft and trailing arm dimensions can vary enough to significantly affect alignment.
Old May 10, 2009 | 11:43 PM
Luke303's Avatar
Luke303
Roger that. How long would it take for a shop to do an alignment?
Old May 11, 2009 | 01:15 AM
Peterbuilt's Avatar
Peterbuilt
If you have new trailing arm shims any shop will correct the toe and camber in just minutes, old trailing arm shims (as you know) are difficult to remove and no shop has replacements. PG.
Old May 11, 2009 | 01:31 AM
Luke303's Avatar
Luke303
The old shims were not very corroded at all so I installed new ones exactly as the old ones, So I'm good there. I suppose when I bring it down I'll bring my extra new ones and they will redo it to correct for variances in the halfshafts and trailing arms?
Old May 11, 2009 | 09:35 AM
1nicecorvette's Avatar
1nicecorvette
should be as easy as pushing the wheel / hub inwards to meet the halfshaft. measure both before attempting this incase the shaft IS too short
Old May 11, 2009 | 09:55 AM
wcsinx's Avatar
wcsinx
Twist the strut rod cam bolt to bring the wheel in closer. It makes installation easier.
To Halfshaft Install Problem
