rear end bangs occasionally 1980 vette
May 10, 2009 | 10:57 PM
has any one had similar banging when punching the gas ?
it happens frequently but not all the time
seems like it slams into the next gear
May 11, 2009 | 09:59 AM
Does the rear "crab" one way when you get on the gas and then back the other way when you lift off?
May 11, 2009 | 11:09 AM
Probably the rear end tounge bushing.
May 11, 2009 | 11:22 AM
St. Jude Donor '09
Have a quick look at the diff mount , it usually only does it on decel or accel, or any mounts for that matter , transmission mount , I'm guessing diff mount! Ron
May 11, 2009 | 03:07 PM
I always heard a banging in the rear was one of the main causes of AIDS...
May 11, 2009 | 05:39 PM
Quote:
Originally Posted by
L88Plus
Wasn't expecting that!
May 11, 2009 | 07:24 PM
trailing arm bush,s flogged out maybe . you should also hear a clunk on braking as well but.L88 that was a good one
May 11, 2009 | 09:16 PM
It sounds like the snubber bushing on the rear end mount or it's time to change the rear lube and add the GM positraction additive.
May 11, 2009 | 10:10 PM
thanks for the responses,,,i think I'll have the rear gear lube changed soon,
the car doesn't seem to crab,,
just seems like a hard transfer to the next gear when punch the gas
May 12, 2009 | 09:22 AM
1980c3tony
Prob. the differential snubber then like others have said. Rotted T-arm bushings will cause the "crabbing".
