Temp sending unit
Old May 12, 2009 | 08:08 AM
BKarol's Avatar
BKarol
Default Temp sending unit
Gauge was not reading so first looked at the temp unit and notice the plastic connector on the wire is broken and the prong on the unit was bent.
Went online and saw a vendor selling a reproduction $30. It said with this unit there is no need to recalibrate the original gauge. Further reading and it appears different brands show different ohms at varying temperatures. This is some old info but interesting read.
http://www.lbfun.com/warehouse/tech_...eCF-Thread.pdf
Does it really matter?
ps. the vendor did state buying this unit will "add value to your Corvette"
Old May 12, 2009 | 08:34 AM
SIXFOOTER's Avatar
SIXFOOTER
Yes it matters. There were different gauges used over the years that needed different resistance sensors. There is no universal sensor that will work will all gauges. There are several vendors that sell the correct unit.
Old May 12, 2009 | 08:39 AM
Peterbuilt's Avatar
Peterbuilt
Got a Wells TU5 at AutoZone, it worked OK for me. PG.
Old May 12, 2009 | 09:11 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old May 12, 2009 | 10:10 AM
...Roger...'s Avatar
...Roger...
Here is a fairly simple way to see if your gauge is in the ballpark.
http://forums.corvetteforum.com/c3-t...uld-share.html
Old May 12, 2009 | 02:37 PM
Vette79C3's Avatar
Vette79C3
I went through two senders after my build before locating one that was very close. I believe it was a Wells Product.
To Temp sending unit
