quick backfiring question
Old May 7, 2009 | 01:01 PM
nomomopars's Avatar
nomomopars
Default quick backfiring question
this past saturday i just put on new plug wires, distributor cap, and a edelbrock 600 cfm carb. the car revs great with no miss at all. on deceleration there is a poping sound. i have yet to tune the carb it is sitting as it did right out of the box. should that be the first thing i do or is it more likely a timing issue? thanks.
Old May 7, 2009 | 07:36 PM
C3 Stroker's Avatar
C3 Stroker
First thing, double check firing order (especially #5 & #7 wires)...if OK, then check timing; possibly slightly retarded, or plug wires might need repositioned 1 hole on cap....if OK, then check plug wires (for good contacts, and not grounded against anything..........when you're satisfied all wires OK, then check carb....begin with float levels and go from there.
This procedure has gotten me out of trouble on several occasions when I thought the trouble was more major.
Old May 8, 2009 | 10:53 AM
justanotherdoe's Avatar
justanotherdoe
If all you did was replace the cap, the timing and distributor orientation should be the same.
A lean condition can cause both carb backfire and exhaust popping. I'd look to the carb adjustments first.
Old May 8, 2009 | 11:25 AM
baxsom's Avatar
baxsom
my 750 speed demon did the same out of the box
1/4 turn out on the needles and no more popping
Old May 8, 2009 | 12:51 PM
nomomopars's Avatar
nomomopars
I thought the needles only affected idle.
Old May 9, 2009 | 02:01 PM
69vettester's Avatar
69vettester
Get a vacuum guage, your engine should hold steady Vacuum at least 15 at 900rpms. If the vacuum readings act strange you may have a open port. or leak somewhere.
Double check the carbs specs. If theres no change, Mark the dist. loosen and move it counter clockwise a tiny bit. Drive it, if its improved move it a tiny more until no popping. If its worse or no better in step one, move the dist Clock wise a little and so forth. if you get no results with the dist. timing. Its the carb. Maybe some debris sticking the float bowl , something like that?
Old May 9, 2009 | 10:57 PM
nomomopars's Avatar
nomomopars
i have a holley street dominator intake, headers, comp cam 224 dur 470 lift, 600cfm carb. what should my timing be set at? what is a good place to start?
Old May 9, 2009 | 10:59 PM
baxsom's Avatar
baxsom
he said it backfires when he lets off the gas
that means it is going back to idle
Old May 9, 2009 | 11:27 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Vacuum leak.
Old May 9, 2009 | 11:57 PM
KevinK's Avatar
KevinK
Mine makes a bubbling sound on deceleration, if it is left in gear...and all I did was go to shorty headers, and true 2.5 duals.
Old May 10, 2009 | 07:32 PM
nomomopars's Avatar
nomomopars
just want to double check. where should the one tower be on the distributor cap.
Old May 10, 2009 | 08:00 PM
nomomopars's Avatar
nomomopars
Now i am getting a fireball out of the carb getting really frustrated here.
Old May 11, 2009 | 12:26 PM
nomomopars's Avatar
nomomopars
would it be worth putting in a new fuel pump?
Old May 11, 2009 | 12:35 PM
kapla74's Avatar
kapla74
I´m really interested in this post same carb out of the box same popping sound on deacceleration...L-82 stock rebuilt...really want to solve it...
Old May 11, 2009 | 01:05 PM
nomomopars's Avatar
nomomopars
kapala, did you richen the carb up any. when mine was runing i richened them up a little and the popping got better.
Old May 11, 2009 | 01:08 PM
kapla74's Avatar
kapla74
I feel my car is actually running rich see my post here on the subject...gas smell bad mpg some black smoke black plugs...etc...or I´am I going in the right directions with my assumptions?
Old May 11, 2009 | 07:30 PM
gingerbreadman1977's Avatar
gingerbreadman1977
was your carb new when you bought it and put it on or was it rebuilt? whats its history cause sounds like its a little sick .
To quick backfiring question
Old May 11, 2009 | 08:17 PM
nomomopars's Avatar
nomomopars
the carb is not even two weeks old yet. the guy before me had a clear inline fuel filter on it. when i went out last night it had gone from clear to a bunch of orangish colored stuff in the filter. i am starting to think it may be a fuel problem.
Old May 11, 2009 | 09:15 PM
gingerbreadman1977
so its less then 2 weeks old but the guy before you had a filter on it? i dont get it.....he didnt have it very long then? sounds like you have found your problem anyway
Old May 12, 2009 | 12:01 AM
nomomopars's Avatar
nomomopars
could that cause a backfire through the carb? Probably not a bad idea to change the fuel pump? the filter looked clean so i didnt change it. i bought the carb new.
