quick backfiring question
Old May 12, 2009 | 02:36 AM
gingerbreadman1977's Avatar
gingerbreadman1977
im lost
Old May 12, 2009 | 07:32 AM
nomomopars's Avatar
nomomopars
mo too lol. sorry about the confusion. could a dirty fuel filter or a nonworking fuel pump cause the backfire in the carb. If a lean condition causes this backfire could this be the reason? Also, can a bad gas cap create a vacum leak?
Old May 12, 2009 | 10:02 AM
noonie's Avatar
noonie
If you say it accelerates well then your timing, fuel delivery, gas filter fuel pump should be close and/or good.
Sounds like you either have a vacuum leak or the new carb is too lean.
Old May 12, 2009 | 10:27 AM
nomomopars's Avatar
nomomopars
now it is to the point where it wont start. it will sputter a little then die, especially if i attempt to feather the accelerator.
Old May 12, 2009 | 02:42 PM
justanotherdoe's Avatar
justanotherdoe
I don't see how the gas cap can cause a vacuum leak.
How old is the gas in the tank? If the inline filter went from "clear to a bunch of orangish colored stuff " quickly, you could be starving the carb, float bowls would be low/empty and this could cause an extreme lean condition.
Unhook the fuel line coming into the carb and see if fuel pumps while you're cranking. Pull the fuel filter out of the line and do the same thing. This should tell you if the fuel pump is working.
If the fuel filter is blocking flow, you may need to drain the tank and figure out where the crud is coming from before you replace the filter. If no fuel is being pumped, that would be the next step.
