Vacuum hoses
Old May 12, 2009 | 01:49 PM
kylec3's Avatar
kylec3
Default Vacuum hoses
Quick question here.
Where can I get a vacuum hose kit. Can I just buy a couple feet of vacuum hose at a local parts store? Is there a cetain size for vacuum hoses for a 74 Corvette?
Old May 12, 2009 | 02:24 PM
71rdster's Avatar
71rdster
Your vacuum hoses are different sizes depending on what they are used for. They are color coded to help you tell which does what. Dr Rebuild has complete kits, and diagrams of where all of the hoses go.
justanotherdoe's Avatar
justanotherdoe
I bought a hose kit for the heater/ac controls, and just bought hose from Lowes or O'reillys for the brake booster, pcv, etc.
http://www.zip-corvette.com/Zip/prod...4F13D0B4CA5276
Old May 12, 2009 | 02:26 PM
Gordonm's Avatar
Gordonm
Yes there are different size hoses for the system. The kits are about 45 or 50 bucks for your year car. It should come with the correct size hoses and plastic T fittings.
Old May 12, 2009 | 02:33 PM
7T1vette's Avatar
7T1vette
If you have some reason to replace all of the hoses [or just want it to be 'purty'], buy the kit from Dr. Rebuild or other Corvette parts outlet. If you just want to fix a short run, just buy take that piece in to the auto parts store (NAPA, etc.) and have them match it for size and length.
Old May 12, 2009 | 03:11 PM
kylec3's Avatar
kylec3
Thanks for teh replys. Do those kits contain all the hoses for the entire vacuum system on the Vette?
Old May 12, 2009 | 03:28 PM
Gordonm's Avatar
Gordonm
The kit listed above is for the AC controls The other kits are for the headlights like this one. http://www.zip-corvette.com/Zip/prod...11A265ACBB7AD4
Old May 12, 2009 | 04:36 PM
kylec3's Avatar
kylec3
Thanks. Well I especially need the vacuum advance one (distributor to carb) since my mechanic cut and blocked it! Also possibly the brake booster one...
Old May 12, 2009 | 04:55 PM
Peterbuilt's Avatar
Peterbuilt
The hoses are 5/32 7/32 9/32, sometimes if you cut 1/2" from the end of the hose and reconnect it might work better. Here's a troubleshooting guide, the text is good but the diagram is wrong so use the one Gordonm posted at Zip. www.corvette-101.com/vacuum.htm
PG.
Old May 12, 2009 | 06:46 PM
IBLather's Avatar
IBLather
Read some of the old CF messages about these parts. There really seems to be some good stuff available and some other krap on the market.
Irv
Old May 12, 2009 | 10:19 PM
7T1vette's Avatar
7T1vette
If your mechanic cut it, have him buy the replacement. There's no reason to cut one, unless the guy is a "hack".... Also, that particular line does not have any special marking, so you could just replace it with the correct size of available tubing.
Old May 13, 2009 | 08:07 AM
kylec3's Avatar
kylec3
Well he cut the hose and plugged it! He set the timing without vacuum advance. But I will be resetting my timing tonight and want to set it with the vacuum advance as it should be....What do you think? Is it ok to have no vacuum advance?
Old May 13, 2009 | 08:20 AM
Paul L's Avatar
Paul L
You can find the hoses at Canadian Tire. They have a pegboard display of all the sizes available.
Old May 13, 2009 | 09:24 AM
7T1vette's Avatar
7T1vette
I would think that any decent auto parts store would carry vacuum line. If not (in your local area) go to a hardware or aquarium supply store and pick up 2-3 feet of clear vinyl/plastic tubing that will fit. That will function until your hose kit order shows up at your doorstep. Oh...all your mechanic had to do was to remove the line from the distributor can and plug that end of the hose. It was idiotic to cut a perfectly good vacuum line just because he was too lazy to do it properly.
To Vacuum hoses
