Starting problems......
Old May 13, 2009 | 04:12 PM
shank0668's Avatar
shank0668
Originally Posted by Kevins77
When you are holding the plate open, pull the throttle. You should see a stream of gas shoot into that area. If you are not seeing that stream of gas, that means your car is not being primed.
If you add gas instead of starting fluid it should start just fine. Sounds like you have a bit of a fuel leak to me.
nope no gas so it should be putting gas in there automatically, Im pretty sure i see a whole about a cm that seems to open and im gonna assume gas comes from there, im gonna take another pic of something.
Old May 13, 2009 | 04:27 PM
shank0668's Avatar
shank0668
This is what i was looking in for gas,
There is also a kink in these lines,
Old May 13, 2009 | 04:53 PM
shank0668's Avatar
shank0668
My older brother said he thinks it gets gas to the carb so there is a pump on the carb?
Old May 13, 2009 | 04:58 PM
shank0668's Avatar
shank0668
Ok heres how it goes I think now starting with fuel pump, fuel pump to carb there is gas, but the gas is not getting to the primary?
Old May 13, 2009 | 05:26 PM
wcsinx's Avatar
wcsinx
I think you need to get your dad to post.
Old May 13, 2009 | 05:31 PM
shank0668's Avatar
shank0668
I know. Lol I tried atleast. He is in nc. Im in ohio right now with his car. I understand mildly whats wrong. Right now I know enough to tell him. Then I have a feeling this will mean tearing apart the carb. Thanks
Old May 30, 2009 | 06:38 PM
shank0668's Avatar
shank0668
Put a new fuel line on and dad said it does not get fuel from pump to carb.
Old May 31, 2009 | 02:58 PM
shank0668's Avatar
shank0668
May be resolved. Gonna drop the tank, one of the lines to or from the tank is cracked. Which would screw up the vacuum.
Old Jun 1, 2009 | 09:57 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
That's a new one on me.
Seriously, if once you get the car started, it runs fine, the problem is not getting gas from the tank to your carb. Think about it, if you had a problem getting gas from the tank to the carb, would the engine run right? No.
Like I said a bunch of posts back. If your car starts and runs fine all day, then you let it sit overnight and it won't start, but then with hand priming it starts, your problem is one of two things:
1. The pump on the side of your carb that squirts the gas for priming is beat or improperly installed.
2. Your carburetor has dried out overnight and there is no gas in the bowl for the pump to squirt down the carb.
We can determine if it is #1 or not quite simply. When cold, you say that there is no shot of priming gas. So, prime the engine by hand, start it and let it run for a few minutes to be sure there is gas in the bowl of the carb. Then, turn off the engine, look down the carb and open the throttle fully. If you see gas, your pump is fine and your problem is #2 above. If you don't see gas, I would replace the diaphram in your pump and see if the problem goes away.
Old Jun 2, 2009 | 08:36 PM
shank0668's Avatar
shank0668
But I figured out that the car doesnt get gas to to carb, meaning gas is at fuel pump but is not getting pumped to carb.
Old Jun 22, 2009 | 03:56 PM
shank0668's Avatar
shank0668
ttt
