Starting problems......
Old May 13, 2009 | 01:30 PM
shank0668's Avatar
shank0668
Default 78 Corvette L-82 Starting problems...... update latest post.
Alright I'm sure many of you have seen some of my staring problems threads........ So I have mentioned that it only starts with...... I thinks it's starting fluid stuff..... Ok what ever you spray it in the carb. Could one of the problems be that there is a kink in the metal line from the pump to the carb? If you start it and let it run for a bit then turn it off it will start all that day without fluid. It also doesnt get fuel to the carb. If you let it run for a while then shut it off then attempt to start it again it usually starts. But it seems to barely turn over. We have replaced the fuel pump with an autozone one. Then we talked to our dealer parts department and they said we probably bought the wrong pump and to get one with some kind of valve. They said either at the dealer or Summit racing. I might be able to get a video of an attempting start. Also if I sound uneducated on cars i am only 12.
Old May 13, 2009 | 02:08 PM
shank0668's Avatar
shank0668
Also I am posting this so I can tell my dad and see what he thinks.. This is his car and he has rebuilt a 73 corvette so he has more knowledge than me.
Old May 13, 2009 | 02:27 PM
Kevins77's Avatar
Kevins77
So let me get this straight. From a cold start, it starts up fine WITH starting fluid in it. WITHOUT starting fluid, it will not start.
When heated up it starts up just like normal?
Im going to ask a dumb question. Are you priming it at all (pumping the throttle to get some fuel into the carb) when you cold start it?
Old May 13, 2009 | 02:37 PM
shank0668's Avatar
shank0668
Yes we are priming it, which im assuming that means pumping gas petal. Well when heated up it seems to hesitate to turn over. But it starts.
Old May 13, 2009 | 02:50 PM
shank0668's Avatar
shank0668
Heres a nice video of my foot.......... LOL This is an attempted start.
http://s291.photobucket.com/albums/l...t=MOV02366.flv
Old May 13, 2009 | 02:56 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Check to make sure your pump on the carb is working to prime the engine. All you need to do is take off the air cleaner and look into the carb while you open the throttle with your hand. If you don't see gas shooting down into the engine, your diaphram on the priming pump is either beat or not properly installed.
I don't recommend starting fluid for a classic car. The stuff is real explosive and I am afraid of punching a hole in a piston with that stuff (like I think I did to my snowblower this winter). If the engine is running reasonably well, you shouldn't need starting fluid.
Turning over slowly when warm is a common problem on big blocks. What engine is in the car? There are things you can do to mitigate this (make sure you are using a heavy duty battery, heat shield on the solenoid, making sure you have all good contacts etc.). If it is a stock 350 and you are having this problem, you need to go through the system.
Old May 13, 2009 | 02:58 PM
shank0668's Avatar
shank0668
Yes its a stock 350........... And I checked and as I can see there is no fuel but i thought i posted that from the fuel pump to the carb there is no gas when you push on the gas pedal.
Old May 13, 2009 | 03:00 PM
Derrick Reynolds
OK, I just read your public profile and you have a '78 with L-82, so it isn't a big block. I watched your video also, and the car sounds like it is turning at the appropriate speed with the starter, I know this is a cold start. One thing on my car, if it sits for more than about a week, the bowls in the carburetor dry out, and the engine won't start until the fuel pump pumps more fuel into the bowls. This takes about 7-8 seconds, which sounds like a lot of cranking, but without priming it by hand (which would be a pain), there is nothing else I can do.
Old May 13, 2009 | 03:03 PM
Derrick Reynolds
And I should also say that IF I was going to prime it by hand, I would prime it with GASOLINE, not starting fluid. So I would have to lift the hood, take off the air cleaner, dump some fuel in, and then start. Once started I would have to put the air cleaner back on and such, too much of a pain. If I burn through a starter motor with all the cranking, I'll replace it and drive on. I don't do that a lot though, in the nice weather I like to drive the car almost every day, so it really only dries out in winter storage, when I am on vacation, or if it sits for some kind of mechanical problem.
Old May 13, 2009 | 03:06 PM
shank0668's Avatar
shank0668
And I checked and as I can see there is no fuel but i thought i posted that from the fuel pump to the carb there is no gas when you push on the gas pedal. I just updated a post with this. Really take the air cleaner off and open those things and put gas in? I will talk to my dad about that thanks......
Old May 13, 2009 | 03:08 PM
Kevins77's Avatar
Kevins77
I agree with this completely. Pull the air cleaner off and watch the flow as you pull the throttle. Make sure that there IS a flow of fuel going in.
It honestly sounds like there is no fuel, or not enough fuel for start-up. Could also be a choke issue I guess, but I would look at this first.
Old May 13, 2009 | 03:15 PM
shank0668's Avatar
shank0668
So your saying when I push down on those things on the carb so you can look in side and just open up the throttle by hand i should see gas? I defiantly don't.
Old May 13, 2009 | 03:24 PM
shank0668's Avatar
shank0668
I am going to assume thats its my fuel lines or fuel pump.
Old May 13, 2009 | 03:26 PM
Derrick Reynolds
Not exactly. When you say "push down on those things" it sounds to me like you are talking about the secondaries, don't look there. See the choke plate in the picture? That is right on top of your primaries, that is where the jet of gas should be. If the engine is cold, just hold the choke plate open with a finger on one hand, and work the throttle on the side with the other while looking down into the primaries. You should see a jet of gas. If you don't, this is your problem.
If this is your problem, there are really only two reasons for it (I stated above like there is one, but really there are two).
1. There is no gas in the carburetor for the pump to push into the carb.
2. The diaghram in your pump is beat or not installed correctly.
I believe you are saying there is no gas in your fuel line from the carb to the fuel pump. If I understand that correctly, then it is likely that the gas in the carb bowl has siphoned out when that line evacuated. This is usually evidence of a fuel leak.
Old May 13, 2009 | 03:34 PM
shank0668's Avatar
shank0668
Are you talking about looking into these?
Old May 13, 2009 | 03:42 PM
wcsinx's Avatar
wcsinx
Are you talking about looking into these?[IMG]
No, the choke plate is the flap on the green shaft at the top of your photo.
Old May 13, 2009 | 03:43 PM
shank0668's Avatar
shank0668
thx brb.
To Starting problems......
Old May 13, 2009 | 03:46 PM
Derrick Reynolds
No. Those are the secondaries. The choke plate is that piece of metal that is mounted onto a horizontal shaft to the left of the circled items in the picture. In this picture, the choke is open, which it normally will be when the motor is warm. But when the car cools down, if you work the throttle, the choke plate will close, and you will need to be fairly quick-eyed to see the jet of gas if you don't hold it open with your finger. So, take off your air cleaner and look down where the choke plate is, you should be looking straight down the primary throttle bodies of your carburetor. Use the index finger of your right hand to hold the choke plate open, and work the throttle with your left hand. You should see a jet of gas shoot down into the primaries. If you do not, the engine is not primed and will not start right away until it gets some gas down in it.
Old May 13, 2009 | 03:52 PM
shank0668's Avatar
shank0668
no gas in there which i was looking in the one that was open in the pic.
Old May 13, 2009 | 04:08 PM
Kevins77's Avatar
Kevins77
When you are holding the plate open, pull the throttle. You should see a stream of gas shoot into that area. If you are not seeing that stream of gas, that means your car is not being primed.
If you add gas instead of starting fluid it should start just fine. Sounds like you have a bit of a fuel leak to me.
