1979 corvette. Does anyone know?
Old May 16, 2009 | 12:27 PM
2box's Avatar
2box
Default 1979 corvette. Does anyone know?
I wanted to replace the clock with the oil temp gauge in my 1979. I came across a 1981 small gauges cluster and I am wondering if I can just install the whole thing in the car and if I would have any problems in doing so.
Old May 16, 2009 | 03:37 PM
PatG's Avatar
PatG
Try calling this guy, he will know.
http://www.corvetteclocks.com/
Old May 16, 2009 | 07:07 PM
jb78L-82's Avatar
jb78L-82
I did exactly what you asked about 25 years ago on my 78. I bought an oil temp gauge and it's sending unit from GM for an 80 -82, removed the gauge cluster, took out the clock, and wired the oil temp gauge into the cluster with a wire for the sending unit to the oil temp temp sensor to the gauge, and jumped a wire to one of the adjoining gauges for power. It has worked perfectly ever since. I did have to remove and reinstall the oil pressure sending unit from above the oil filter to behind the distributor at the top of the block where on the corvette there is a plug. I bought some fittings from a local hardware store (no home depot back then) and installed the oil pressure sending unit. I installed the oil temp sending unit above the oil filter since I believe that is where GM originally mounted their units. Hope this helps!
Old May 16, 2009 | 07:59 PM
markdtn's Avatar
markdtn
The hardest part is finding the sending unit. They have been discontinued by GM for some time and the aftermarket does not have an exact replacement.
Old May 16, 2009 | 09:41 PM
spikebot 81's Avatar
spikebot 81
All the vette venders have the sensor. I got one that is exactly like the stock sensor. Get ready to shell out about 80 bucks
Old May 16, 2009 | 10:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Run a search, someone just did this step by step about three weeks ago. I worked with him on this but for the life of me can not remember who the OP was.
Willcox Inc.
Old May 17, 2009 | 10:43 AM
Ganey's Avatar
Ganey
Yes the clusters would swap. Run a wire for the oil temp sensor which can be connected directly to the gauge. Check wiring to oil temp gauge since your car wiring was for the clock.
Added oil temp gauge when it came out & changed to the later panel several years ago.
Old May 20, 2009 | 11:21 AM
2box's Avatar
2box
Thanks.. Do You remenber how wire the gauge? lets say the cluster is out of the car and I have it infront of me does it go signal, -, + or the other way? Thanks for any help..
Old May 20, 2009 | 11:24 AM
2box's Avatar
2box
Thanks for the help.....
Old May 20, 2009 | 11:26 AM
2box's Avatar
2box
I have everything. The only thing I am having problems with is the wiring. I do not know if where each wire plugs in the back of the gauge. I do not have a plug So I had to run the cables up to the gauge myself.. Thanks for the help
Old May 20, 2009 | 11:37 PM
toyvet1's Avatar
toyvet1
three prongs on back of gauge send- grd -power/ing. Ground to ground, 12v to send prong and ing prong to send unit. Dont ask me why the are reversed but that what it took to get mine working back in about 81 . Bench tested before install with hot water and a battery.
To 1979 corvette. Does anyone know?
