Rivet tool?
Old May 17, 2009 | 02:44 PM
Duke94's Avatar
Duke94
Default Rivet tool?
I have to rivet the spare tire carrier support member to the fiberglass tub. I have the aluminum rivets so what did you use to peen them over? Since the rivieted end is on the outside, what kind of tool can I make so it will look decent? Something besides a hammer.
Gary
Old May 17, 2009 | 03:10 PM
TOM B1's Avatar
TOM B1
You can buy a air chisel and then get the rivet tool to fit, snap on tools has them but you will pay for it with your life, KD tool has them for a reasonable price. Then you will need a bucking bar or a thick piece of steel, A good heavy ball peen hammer or small sledge will work to. Of course you need a AIR compressor!!!
68AIR's Avatar
68AIR
Default rivet set
I used a rivet set which is a piece of tool steel that has a hollowed area on one end. I purchased a few extra rivets and practiced and found that the the hole that is drilled in one side of the set (about half the diameter of the rivet)is a better match for the original peening then the carved out area was. basically it smashed down the outsides of the rivet and left the middle higher. I placed the tub on a stand with a flat piece of metal (buck) to support the rivet from the inside of the tub. I also placed a piece of masking tape to hold the rivet in place and protect the finish of the tub inside. placed the rivet set on the rivet and gave it a whack. Worked perfect!
Old May 17, 2009 | 03:19 PM
TOM B1's Avatar
TOM B1
I see that sears has a chisel tool for about 50 bucks but cant find the rivet end, I looked on Ebay under, Air rivet, and found some good sets for about 30 bucks and you get 3 sizes of rivet ends, Not snap on quality but will work for lots of rivets
Old May 17, 2009 | 04:58 PM
bluthundr's Avatar
bluthundr
If you don't care about originality, I just used 1/4 carriage bolts. Head on the inside so they don't damage the tire, lockwasher and nut on the outside and then cut the bolt flush with a dremel.
Old May 17, 2009 | 06:26 PM
Alan 71's Avatar
Alan 71
Hi Gary,
I used a large finishing nail 'set', which had a slightly hollowed tip, that I found at the hardware store.
The aluminium was soft enough that I could get a nice 'mushroom' shape by moving the tool angle around a little.
Regards,
Alan
Old May 17, 2009 | 06:29 PM
windup's Avatar
windup
This any good to you?
http://www.zip-corvette.com/Corvette...46FB37F154DEA0
Old May 17, 2009 | 08:24 PM
jknb1205's Avatar
jknb1205
6th Gear
I recently replaced a rear body mount that required rivets, I took one of the attachments that came with the air hammmer and cut off the end then took a drill and drilled out a shallow dish on the end, this worked awesome, start out with low air pressure and slowly increase to get desired rivet dome. as mentioned before place hammer or dolly on opposite side of rivet.
Old May 17, 2009 | 10:06 PM
barbs '69 resto's Avatar
barbs '69 resto
Account disabled by request 8 Feb 2010
Default rivit tool
I did the exact same thing as JKNB and it worked beautiful.
Old May 17, 2009 | 10:18 PM
GDaina's Avatar
GDaina
Yep, that's what I did, modified a damaged air chisel...but I whacked it a couple times with a hammer, came out great...total cost.....$00.00
Old May 17, 2009 | 11:01 PM
BigBlockTank's Avatar
BigBlockTank
WOW............
I do sheetmetal everyday (for the past 34 years). Browntool.com has inexpensive metal working tools and the get it to you fairly quick. Mind you, they are a bit like Harbour Freight on some items, but the tools get the job done and professionally looking too.
I just looked at the website. They ain't cheap no more. Get the proper tool for the job, is all I can say.
Old May 18, 2009 | 08:52 AM
70BBvert's Avatar
70BBvert
The rivet sets are available at any aircraft tool supply company for a standard air chisel. I bought a couple on line at:
http://www.aircraft-tool.com/shop/se...ORY=Rivet+Sets
Just remember to adjust the air pressure down to 30 psi or so IIRC, otherwise the tool will jump around. The soft aluminum doesn't need a lot of pressure to peen over well. Play around with a test piece first. You can use a body dolly to back up the rivet.
Jim
Old May 18, 2009 | 02:54 PM
Duke94's Avatar
Duke94
Jim
Why didn't I think of that! My sons best friend is an aircraft mechanic and has all kinds of riveting tools, said he'd even come over and do it for me.
Thanks for all the suggestions.
Gary
Old May 19, 2009 | 05:03 AM
hunt4cleanair's Avatar
hunt4cleanair
Jim
This sounds like the ticket but let me see if I've got this straight. you use your air chisel and than pick up a couple of the rivet bits. To reduce "jump" you turn pressure down to 30 psi.
What size did you get for the tub rivets?
What's IIRC?
thanks
Old May 19, 2009 | 08:54 AM
70BBvert's Avatar
70BBvert
Originally Posted by hunt4cleanair
Jim
What's IIRC?
thanks
IIRC = if i remember correctly
I turn the pressure down to the lowest that the air chisel will still work at and then bring it up a little at a time until I'm at a pressure I can work at comfortably. The majority of the time I'm working by myself & I need to hold the bucking bar &/or the piece I'm working on. I usually making a jig to hold things, the fender skirts were a lot of fun
I only by the longest rivets, from Doc rebuild, put them through both parts & cut to length. I leave an 1/8" or so to peen over.
Jim
Old May 20, 2009 | 05:17 AM
hunt4cleanair
Jim
I wasn't clear with what I asked "what size rivet tool did you get for the tub?"
Old May 20, 2009 | 08:03 AM
70BBvert's Avatar
70BBvert
Jim
Sorry, I don't remember whether it was 1/8" or 3/16". Just measure the diameter of the rivet & buy the same size tool.
Jim
To Rivet tool?
Old May 20, 2009 | 02:19 PM
Duke94's Avatar
Duke94
I got a little education on rivets today (at least aircraft type). The rivet tool (see pic) I had to use was for a 3/16" semi spherical head rivet. So the head of the rivet fits into the pocket in the rivet tool and the bucking bar is suppose to go on the side you smash over. Unfortunately, the rivets for the tub have a flat head and we had no flat head riveting tool. So, we put the bucking bar on the flat head side and peened over the rivet with the rivet tool resulting in a spherical shape head instead of a flat head. They look great but not original. I think I’ll go back now with just a hammer, dolly and punch to flatten them out. The soft aluminum rivets are very easy to work with. We set the air pressure at 30 PSI which was more than enough. Thanks to everone for your input.
Gary
Old May 20, 2009 | 04:44 PM
Alan 71's Avatar
Alan 71
Hi Duke,
The procedure you described is how I've always believed the rivets were done on the assembly line... bucking bar on head side and pneumatic smash on shaft side.
Regards,
Alan
PS: NICE looking surface on that tub!!!
Old May 20, 2009 | 04:50 PM
70BBvert's Avatar
70BBvert
Gary
Gary
I think you have that backwards, The bucking bar on the flat & the tool peens the rivet. It looks perfect in the picture to me. I wouldn't do anything further. Take a look at some of the factory rivets as a reference. They won't look as nice but you'll see the rounded over stub.
It may be different on aircraft, but if you think about the tool shape for this application I think you'll agree. In the aircraft tool supply catalogs there are different shape bucking bars as well as rivet sets to access tight areas. Some of the rivet sets are flat at the end as well for other applications.
Jim
