I'm installing a 200-4R transmission from BTO, and need to tap into the brake light circuit (for Bosch Relay and lock-up). For a '78 with cruise, can anyone tell me the correct wire to tap into from the brake light switch? Also, if there's a better place to connect into the brake light circuit, I'd be interested to hear as well. Thanks for any help!
Thanks bluthundr - these diagrams will be very useful.
DWncchs - that's exactly what I was looking for. Torque converter unlocks (in OD) when pressing on the brake...to make this happen, the TCC wiring taps into the "brake light circuit". That's the circuit I was looking for coming out of the brake light switch (made hot when pressing on the brake).
Thanks Duke94 - Diagram is very easy to read. Appreciate your help. This is my first "C3" project, and everyone here has been very helpful. Like others, I started with the "rear end", and ended up pulling the engine. I'm just looking forward to the day I can take the jack stands down and take it for a spin.
