Windshield molding replacement - need to remove windshield??
If anyone has gone through this recently, I would appreciate any comments - is it possible to replace windshield corner chrome moldings without removing the windshield?? My original ones are quite ugly. Just in case, I'm talking about these parts:
Thank you, guys! I think, I will just spray some chrome on these moldings for temporary bubba-fix Just don't feel like removing my windshield at the moment :o
it can be done, but it's a job. you'll have to use a dremmel to cut the heads off the two mentioned screws and then lift the end piece. then when you reinstall the pieces, the trick is to make short studs out of screws to replace the screws. then there's just enough room to get a small end wrench on a nut to tighten the studs holding the end piece. the problem is that a normal screw can't be started or tightened because of the edge of the glass. any pressure on the edge will crack it.
not that i ever did this, but i knew a guy that knew a guy that heard a story about some dumb guy in florida that set his windshield before he set the end pieces.
