Tick
Old May 21, 2009 | 10:14 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Tick
In my 79 L-48, I replaced the spark plugs and wires about six months ago. I have a ticking sound that sounds like it is coming from the distributor. Can anyone give me any advice as to what I should do to get rid of the ticking?
Any advice would be much appreciated.
Thank you
Doug
Old May 21, 2009 | 10:43 PM
...Roger...'s Avatar
...Roger...
If the cap is slightly off the rotor can make a click. The pickup if not aligned can also click.
Old May 22, 2009 | 04:52 PM
Doug Maitlen
Should I try replacing the cap and rotor?
Old May 22, 2009 | 08:00 PM
...Roger...
Just remove the cap and see if you can see if the rotor has been hitting.
Old May 22, 2009 | 08:08 PM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
When it's dark fire it up and see if you can see a spark arching somewhere. Could be a defect like a small hole in one of the wires.
Old May 22, 2009 | 08:47 PM
Doug Maitlen
How exactly do I know if it has been hitting?
Thank you
Doug
Old May 22, 2009 | 10:41 PM
CCrane65's Avatar
CCrane65
Look for an errant spark. If there is any void in the plug wire the spark will seek the nearest ground causing a miss.
cc
To Tick
