Ignition Module
Old May 23, 2009 | 04:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Default Ignition Module
Ignition Module 81, orig distributor.
Looks like I need a new one.
Anything new on the technology? I.E. better than Delco.
Any and all experiences and recommendations needed.
Old May 23, 2009 | 06:22 PM
Wrecked82's Avatar
Wrecked82
I bought a DUI ignition module when I bought the DUI coil. Ignition module lasted about 3 years and then died on the road. Put the original module back in and its worked fine. That makes it 24 years of use. Maybe I'm living on borrowed time?
Old May 23, 2009 | 06:28 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Thanks for the reply.
On will be on #2 in 80,000 miles.
Heat, they say is the killer.
DUI?
http://www.chevyhiperformance.com/te...les/index.html
Old May 24, 2009 | 01:28 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
No body has had to replace a ICM?
Should have asked in C4 I guess.
Old May 24, 2009 | 07:35 AM
'75's Avatar
'75
I'm using one from Summit, but i carry the original as a spare, it was still working.
Old May 24, 2009 | 05:23 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
DUI?
Stick with an OEM Delco EST module. They're more electrically robust, and the technology they're made of will put up with heat better than the aftermarket stuff.
Old May 24, 2009 | 05:34 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I appreciate the reply.
Old May 24, 2009 | 06:08 PM
Ganey's Avatar
Ganey
Wells is an OEM supplier & avail. at Auto Zone.
Old May 24, 2009 | 06:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old May 24, 2009 | 09:17 PM
TimAT's Avatar
TimAT
And make sure you install the new module with heat-sink compund under it.
Old May 24, 2009 | 09:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old May 25, 2009 | 08:50 AM
jb78L-82's Avatar
jb78L-82
I have used a crane HEI replacement module for about 7 years with a Hypertech high output coil. The coil died on the road and hypertech replaced it free but I still worry about both. I used a GM module and Accel supercoil for 20 years prior to the change with zero issues.
Old May 25, 2009 | 09:35 AM
FB007's Avatar
FB007
Funny, I thought Delco made Delco.
To Ignition Module
