C3 Rear Spring Rubber Donuts
Old May 24, 2009 | 07:00 AM
Thmprr's Avatar
Thmprr
Default C3 Rear Spring Rubber Donuts
Six weeks ago I replaced the rubber donuts on the spring hanger bolts, on our '76. At the time I thought it strange that there was no cup under the spring leaf to receive the rubber donut top flat flange. The spring has a 1" hole, but nothing else. There is a large heavy curved washer under the lower curved rubber donut face, but the 1" hole in the spring looks way too big to receive the rubber donut shank.
What's happened is the donuts have split radially and the hanger bolt is in danger of squishing the rubber out and going steel/steel. Have my springs lost these cups?
In any case, I'm going to machine some because I think its better if the rubber donut is contained better against the spring.
Old May 24, 2009 | 08:49 AM
Paul L's Avatar
Paul L
The curved washer/cup goes on the spring first (mine shown in black), then the cushion, then the flat washer and nut.
Here you can see the flange that is pushed into the hole in the spring.
Old May 24, 2009 | 10:47 AM
CCrane65's Avatar
CCrane65
I have a set of steel cups that were taken off my car last winter when I replaced the spring and trailing arms. They are in good shape and just need cleaning if you are interested.
cc
Old May 24, 2009 | 02:13 PM
Alan 71's Avatar
Alan 71
Hi T,
There have been more than a few comments recently about the quality of the rubber bushings and the fact that they split as you described with very little use.
You may want to try some from a different source or perhaps someone can make a suggestion of a vendor's bushings they've had good luck with.
Regards,
Alan
Old May 24, 2009 | 02:44 PM
J. Scott's Avatar
J. Scott
Alan 71:
Dittos. On another current thread regarding bushings I am asking if folks have found the huge price difference between GM bushings and others to be worth it.
Can anyone offer some personal experience here?
Old May 24, 2009 | 06:27 PM
stock76's Avatar
stock76
I replaced mine with urethane cushions. Two of them just crumbled and fell apart and the other two had cracks in them. This was in less than 500 miles.
I replaced them with rubber cushions and a year later the rubber ones still look like new. I bought them from a local Corvette shop and parts supplier. They were loose and not in a bag so I doubt they were OEM parts but they are working just fine. I think I paid something like $2.50 for each cushion - they were pretty cheap.
Old May 24, 2009 | 07:09 PM
Blue73Shark's Avatar
Blue73Shark
I have to replace the original ones in my 73. Questions:
1) how difficult a job is this to do?
2) what equipment is required to do it yourself"
3) where did you get the parts and can you post a list of what you got?
Old May 24, 2009 | 08:00 PM
stock76's Avatar
stock76
Try this link. http://www.corvettemagazine.com/tech...-and-more.html. Scroll down to the section on the spring bolt/cushion replacement.
1. This is one of the easiest jobs to do; maybe 10 - 15 minutes per side.
2. You need a good jack, large "C" clamp (4"), a block of wood, wrenches, and pliers to pull out the cotter pins. Spray some PB Blaster on the nuts and bolts a day or so before to loosen them up.
3. If the bolts and hardware are still good you can reuse them and just buy the spring cushions. You will need four. If not you can get a kit with new bolts washers and cushions. They are available from a number of supporting vendors on this site. I'm pretty sure that both Wilcox and Vette Brakes carry them.
Old May 24, 2009 | 10:13 PM
RunningMan373's Avatar
RunningMan373
Originally Posted by J. Scott
Alan 71:
Yes, i replaced mine twice with aftermarket rubber ones, they started to crack to pieces within 1 month, see pic below. I then changed suppliers to Van Steel and ran polys. I'm very happy with them going on 6 months. Get the GM set or a set of polys from V/S.
New, bring installed (first set):
After 1 month(2nd set, changed rear bolts on 2nd replacement):
Polys
It's pretty easy, but can be dangerous, if not done right. Stock76 covers the tools pretty well, use the C-clamp to clamp the jack to the spring for safety. I jack-stand the rear end, then put a spare tire under the side i'm working on in front, for safety. I then put jack, piece of 2x4, and clamp the jack to the spring, just inside the wheel, first flat of the lowest leaf. Put the jack in line (accross car) with the spring, so it can 'walk/roll' with the spring, as it's lifted. jack it up till I just see the pressure just come off the lower bolt bushing, then R&R them. easy really.
Old May 25, 2009 | 06:11 AM
cajos's Avatar
cajos
Related question how do you get the rear stabilizer bracket on?
Old May 25, 2009 | 06:26 AM
RunningMan373
I don't have a Gymkana. maybe someone else will chime in.
Old May 25, 2009 | 07:29 AM
Paul L's Avatar
Paul L
The cushions I put on a couple of weeks ago are rubber. I bought them at Carlisle ~8 years ago when I had a 1979 but....they became a round-to-it. That is pretty much the pre-Chinese era so they should be OK but I'll keep an eye on them.
These are the ones I took off my 1974. Pretty sad.
Old May 25, 2009 | 11:20 AM
CCrane65's Avatar
CCrane65
With the wheels jacked up at normal ride height there is room for the nuts and nutplate between the spring bolt and the trailing arm.
cc
Old May 25, 2009 | 12:28 PM
cajos's Avatar
cajos
Really??? Seems impossible..
Old May 25, 2009 | 04:18 PM
CCrane65's Avatar
CCrane65
If you notice, the spring flattens out when the wheels are on the ground. The angle of the bolt changes and the bolt lowers as the spring tension changes.
cc
Old May 26, 2009 | 11:33 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
cc
You will most likely have to tap the flat plate in place with a hammer and tweak it with a screwdriver to get it lined up.
Old May 26, 2009 | 11:49 AM
cajos's Avatar
cajos
Tweak!! Why not say pimp ;-) Just kidding. Thanks will try later this week.
Old May 26, 2009 | 12:04 PM
CCrane65's Avatar
CCrane65
When you do, the holes are offset, install them with the longer end sticking out the back of the trailing arm.
cc
To C3 Rear Spring Rubber Donuts
