HELP! my engine is surging at idel. why?
Old May 24, 2009 | 06:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Originally Posted by Joe Hilber
so iput a new advance in and no frikin luck! thanks anways guys!
You need to tune it up properly.
Base timing
Idle adjust
Do you have a timing light?
Dwell meter
Hand held tach?
I suspect dist probs.
But i don't read well.
Old May 24, 2009 | 06:14 PM
stock76's Avatar
stock76
Make sure your timing is right. Make sure the carburetor is adjusted properly. Check for vacuum leaks.
If the car was running ok and then just started this, check the vacuum advance like others have suggested. If that is not it, then start looking for vacuum leaks. A vacuum leak can cause surge at idle. Is you car an automatic? Check down at the vacuum modulator on the transmission to see if the small piece of rubber vacuum line that connects the modulator to the steel line that runs up to your manifold port is cracked or got knocked loose. That will cause a surge condition for sure. After checking everything else on mine thats what was causing it. Naturally it was the last place I looked....
Good luck finding it.
Old May 24, 2009 | 09:50 PM
FB007's Avatar
FB007
Originally Posted by calwldlife
[/B]
not right.
Vacuum advance "should" not add much if any advance at idle.
Wrong. Just the opposite.
Old May 24, 2009 | 09:58 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
ported vacuum on carb won't show vacuum until off idle.
He unplug it and the car stalled.
Not normal.
Manifold vacuum is no a stock condition.
Vacuum advance modules are rated a in vacuum when they engage and when full travel.
So wrong back at ya
Old May 25, 2009 | 12:41 AM
Jayson77's Avatar
Jayson77
Ive heard that if you store a car with winter gas the car will idle or act diffenerntly depending on the temperature and humidity when you start it up the first couple of times right out of storager. The same would be for summer gas in the winter. Has anyone else heard of this?
Old May 25, 2009 | 04:00 AM
FB007's Avatar
FB007
Not normal.
So wrong back at ya
Your right. I have capped all ported vacuum ports for so many years, I forgot people still used them.(God knows why)
Old May 25, 2009 | 09:06 AM
tommyleea's Avatar
tommyleea
Do you have air conditioning? Do you have an idle solenoid? Is the air kicking on and off?
