HELP! my engine is surging at idel. why?
Old May 24, 2009 | 03:06 PM
Joe Hilber's Avatar
Joe Hilber
Default HELP! my engine is surging at idel. why?
its a 77 with quadrajet. it idels at 6 hundred and then soots to 2 grand. i cant even driv the car its so bad. and its my only tranportation for a month or so. car ran fine last fall minus the chock woundnt stay on long to warm the moter up. please help me!!
Old May 24, 2009 | 03:32 PM
J. Scott's Avatar
J. Scott
Is there an Exorcist in your area? Seriously, that isn't even an option in my troubleshooting guide. Sorry. Can't wait to see what the solution is.
Old May 24, 2009 | 03:44 PM
Joe Hilber's Avatar
Joe Hilber
great! not really. thanks fr at least responding though. i have a funny suspision it might be this vacume diafram that is conected to my disributer. it hangs of the right side of the distributer and has a vacume hose running to the front of the carb. what is it and what does it do?
Old May 24, 2009 | 03:46 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Does it stumble then go up in rpms, or does it cycle up smoothly?
Old May 24, 2009 | 03:52 PM
Joe Hilber's Avatar
Joe Hilber
smothly
Old May 24, 2009 | 03:57 PM
DRIVESHAFT's Avatar
DRIVESHAFT
That thing on your distributor is the vacuum advance can.
While adding or removing vac advance will affect idle speed, the behavior your describing is really strange.
You can remove the hose temporarily though to see if the surging stops.
Old May 24, 2009 | 04:02 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
smoothly
Stock motor, emmisions?
Old May 24, 2009 | 04:03 PM
J. Scott's Avatar
J. Scott
That would be your vacuum advance unit on the distributor which increases your spark advance as manifold vacuum increases. Your idle speed will increase when it is engaged. This still doesn't easily explain things.
Is there any chance it was not working at all last Fall and your idle was adjusted then? Now, for some strange reason it has resumed working intermittently and is raising your idle when it does?
Admittedly, this is a far-fetched scenario but I can't think of anything else other than possibly some carburetor problem that could possibly cause an rpm increase like that. I don't have any carb expertise that could explain this but maybe someone else does.
The good news is that a vacuum advance unit is only $15-$20 and very easy to change out. You might want to check out this "Sticky" on timing at the top of the C3 Tech page http://forums.corvetteforum.com/c3-t...long-post.html. It will help you get your engine running its best. I just used their tips and my car has never run better in the nine years I have owned it.
Old May 24, 2009 | 04:04 PM
Joe Hilber's Avatar
Joe Hilber
tried it. it semmed to help kind of. it made it a litlle better but still doin it. if i drive it i have to put it in nutral at a stop light. and then it just lump lump lump whaaaa lump lump lump whaaaa!
Old May 24, 2009 | 04:08 PM
Joe Hilber's Avatar
Joe Hilber
thanks for the help. il try the advance and go to the sticky. ill let you guys know what it turns out to be. give me a couple days. i dont think napas open till tus wit the holiday and all. and of course if anyone has a for shur fix it pointer please give it to me at any time. ill be watching. thanks gents
Old May 24, 2009 | 04:09 PM
dannyman's Avatar
dannyman
Electric or mechanical choke?
Warm enough outside right now to wire your choke mechanism in the off position, and operate the engine. If your RPM remains stable you know you have a choke control issue. If choke is electrical, check for a lack of voltage to choke. If choke is mechanical, the problem could be linkage seizing or binding, or an adjustment is required.
If the RPM is still fluctuating it is a fuel delivery issue.
Joe Hilber's Avatar
Joe Hilber
the moter is rebuilt stock. no emitions stuff that i know of.
Old May 24, 2009 | 04:11 PM
Joe Hilber's Avatar
Joe Hilber
so how do i wire the chock i the off position?
Old May 24, 2009 | 04:15 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Napa is open here in Ca.
Not hearing it or seeing it:
FLoat valve leaking
Vacuum leak, Smog device
Carb vacuum break
Timing chain loose
Power valve spring riding on vacuum surging causing flutter
Hei Ignition module
Idle set wrong and air screw adjust wrong magnifying power valve flutter
Timing wrong
Ported vacuum from carb signaling the advance- carb misajusted
Old May 24, 2009 | 04:16 PM
dannyman's Avatar
dannyman
Look inside the top of carb and move choke linkage until the choke butterfly is in full open position and tie off the linkage to keep it in that position so it does not close.
Old May 24, 2009 | 04:20 PM
Joe Hilber's Avatar
Joe Hilber
ok great ill try the choke deal. give me a few min ill let you know if works. and thanks so much everybodys help!!
Old May 24, 2009 | 04:46 PM
Joe Hilber's Avatar
Joe Hilber
ok well it looks like its the vacume advance. its on its way out. it works better nowafter i waked it a few times with the screw driver. and if i unhook the vacumeline it dies.
To HELP! my engine is surging at idel. why?
Old May 24, 2009 | 04:53 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
not right.
Vacuum advance "should" not add much if any advance at idle.
Vacuum line removed should not kill motor.
When you set timing did you remove and plug vac advance line?
Sounds like a combo of wrong basic timing and bad carb idle adjust
Or advance weights and springs sticking or loose.
Old May 24, 2009 | 05:53 PM
Joe Hilber's Avatar
Joe Hilber
so where is the fuel filter located
Old May 24, 2009 | 06:03 PM
Joe Hilber's Avatar
Joe Hilber
so iput a new advance in and no frikin luck! thanks anways guys!
