Engine miss at idle
Old May 24, 2009 | 07:24 PM
Ratsirt's Avatar
Ratsirt
Default Engine miss at idle
Have been experiencing problems with my engine missing at idle. It appears to happen when the dual spal fans come on. I do have a 100 amp alternator and this problem is new. Did not happen in the past. Any ideas? Could my alernator at idle now not be producing sufficient amps at idle for the MSD and Spals?
Old May 24, 2009 | 09:41 PM
wombvette's Avatar
wombvette
Probably vacuum leak off of the 5-8 runner. Thats the vacuum source for most of the systems.
Old May 25, 2009 | 10:20 AM
Ratsirt's Avatar
Ratsirt
Don't think it is a vacuum leak, it only happens at idle with fans running.
Old May 25, 2009 | 10:29 AM
'75's Avatar
'75
You could check the voltage at idle with the fans on to see if that's the problem.
Old May 25, 2009 | 12:19 PM
moss4wvu's Avatar
moss4wvu
it might be something with the emissions..I had a car that idled terrible and it was the egr valve.....it was full of carbon.
Old May 25, 2009 | 09:51 PM
wombvette's Avatar
wombvette
I have been doing this for about 35 years, and that is the most common cause of miss at idle. I wouldn't dismiss it off hand.
To Engine miss at idle
