intermitent wipers
Old May 25, 2009 | 03:09 PM
TPI BOY's Avatar
TPI BOY
Default intermitent wipers
Anyone install these in a c3 with standard wipers
Old May 25, 2009 | 03:34 PM
mrvette's Avatar
mrvette
Yes, with linear actuator on the operating '72 door also....
but you have to be into electronics, or forgetaboutit....
unless you really good with wiring, then maybe a aftermarket kit can be worked in ....maybe even with a vacuum operated door....
Old May 25, 2009 | 04:11 PM
TPI BOY's Avatar
TPI BOY
Can you use the system out of a newer c3
Old May 25, 2009 | 08:28 PM
TPI BOY's Avatar
TPI BOY
Anyone know
Old May 26, 2009 | 05:48 PM
TPI BOY's Avatar
TPI BOY
bump
Old May 27, 2009 | 04:09 PM
TPI BOY's Avatar
TPI BOY
[Onemore time
bump
Old May 27, 2009 | 06:35 PM
Bob Walker's Avatar
Bob Walker
I'm interested in your question and thought someone may have come up with a solution, but not loking good. I tried this by installing a Hella Intermittent Control Unit (On a '75, so no door to worry about). Thought I had it done, without the wiper arms on, the wiper pivots would do one turn under control of the Intermittent switch. Put the arms on and found that they didn't move, the wiper motor was still in "park" mode. I've had other problems with the car, so haven't got back to this, will will in due course.
Old May 27, 2009 | 06:58 PM
mrvette's Avatar
mrvette
AFAIK, late shark int wiper modules are not available, or cheep, then you get into interfaces with early shark switches/motors...let along wiper doors...I never heard of anyone making a unit that would fit all the various configurations, as anything stockish that could fit a variety of installs...
everything I have picked up on, says you are on your own, just as I was....
come think of it, I never documented my intermittant wiper electronics...not even a schematic....
Old May 27, 2009 | 09:45 PM
TPI BOY's Avatar
TPI BOY
Lets say, any year that doesn't have a wiperdoor door.
I seems you should you could get the modules out
of a wrecked vette and use them, what do you
think
Old May 27, 2009 | 11:30 PM
Young69Owner's Avatar
Young69Owner
What I was going to try was something like a volume **** and a capacitor wired to the normal speed wire on the switch. This is a very low priority for me at the moment. Oh and the wiper door should go up and down each time.
To intermitent wipers
