4-speed shifter rattle
Old 05-29-2009, 01:17 PM
71SoCal
71SoCal's Avatar
Default 4-speed shifter rattle
On my 1971, the stock 4-speed shifter really rattles at high rpms. It's that reverse finger-pull mechanism on the shifter. I have to keep my fingers on it the whole time I'm driving to keep it quiet.
I've taken it apart, and it just seems like that's how it's designed. Is there some rubber/other material part that I might be missing?
Thanks...
Old 05-29-2009, 01:27 PM
TXredc3
TXredc3's Avatar
Maybe the spring for the backup part of the shifter is worn out. I'd stretch it to see if this creates more tension on the part.
Old 05-29-2009, 03:35 PM
WillEE
WillEE's Avatar
Just a thought - maybe if you packed some vasaline into it would be enough to stop the rattle.
Old 05-29-2009, 03:51 PM
Vegas69
Vegas69's Avatar
Packing Vaseline around your "reverse finger-pull mechanism" ? That don't sound right.
Old 05-29-2009, 03:56 PM
roscobbc
roscobbc's Avatar
Go buy a Hurst shifter - that will sort that problem + others
Old 05-29-2009, 04:05 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Although the Vasoline might feel better, I'm with Tex, and thinking the spring might need to be stretched a little to put more tension on the reverse lock-out in the shift ****.
Regards,
Alan
Old 05-29-2009, 04:18 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Has worked for me on more than one occasion
Old 05-29-2009, 04:56 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
actually the Hurst bolts to the trannsmission,
it will multiplie any drive train vibration you have.
going down the road if you shift into neutrual does the vibration go away ?
the stock shift bolts to the frame cross member, which reduces drivetrain vibrations
that get transmitted thru the shifter. 69VETT
Old 05-29-2009, 06:14 PM
dennis
dennis's Avatar
Have to dissagree. I know what your saying, the logic makes sense.
Had the stock rattlesnake shifter for years. Soon as I changed to a hurst ....bye-bye rattle. Don't know why that is,(don't want to think about it).
Old 05-29-2009, 06:53 PM
spedaleden
spedaleden's Avatar
I feel your pain. What I did is remove the ball and get a felt washer and place it between the reverse lock out on top and the ball. Trim washer as needed.
Old 05-29-2009, 10:47 PM
barbs '69 resto
Account disabled by request 8 Feb 2010
barbs '69 resto's Avatar
Default rattle
I've found that after awhile a grove will wear into the barrel of the slip yoke and play will develope between the yoke and the tail bushing of the tranny which will cause vibration and shaking the shifter. Also go to a service shop and have them inject grease into the shifter housing if you want.
Forget the Vaseline.
Old 05-29-2009, 11:00 PM
Wavbyby
Wavbyby's Avatar
I agree!!! I found the same cause and effect!! on my 70BB. While your at it intall all new ujoints. 1 bad joint can cause a big vibrations
To 4-speed shifter rattle
Quick Reply: 4-speed shifter rattle
