I just replaced the power steering pump valve cylinder and hoses. The old stuff worked well but was leaky and ugly. Now my steering is very stiff and a little erratic the wheel needs to be turned both ways, it doesn`t come back by itself. Any ideas?
Yes Sir; I'm sure you will find a lot smarter person, but it sounds like you need to Balance your power steering control valve. You can get that info. from the co. that sold you the parts or from the Corvette Shop Manual. I know Wilcox will have the info. if you just ask. Have a great weekend. Gene
Did you grease the fitting on the control valve? If so, too much grease causes hard steering. Also, you could have a bad control valve. I went through 3 "rebuilt" ones before I got a good one. Try the balance procedure first.
I balanced it once. should I do it again. The valve and cylinder came from willcox the pump from oreilly`s. Could it be the pump since it steers hard both ways?
Did you bleed the air out of the PS pump after you installed it? If there is still some air left in the system the fluid will be foamy when you check it. That could give you the problem too.
I also have a problem with my steering wheel not returning by it self
back to center after I put in a new valve and cylinder. Seems to be
worse on left turns. I checked the balance on the valve and it's good.
I'm going to try to disable my power steering to see if the problem goes
away. If it don't go away I might have an alignment problem. I rebuilt
the front suspension at the same time I put the new valve and cylinder
on.
on.
Did you have a alignment after the rebuild? If the caster is off (not enough of it), the wheels won't come back very well.
Mine was working fine. I only put the new parts on to clean it up. Now it`s bad, very stiff in both directions and it won`t come back to center. I centered the valve again and no help. I`m about ready to put the greasy old stuff back on.
It sounds like you got a bad valve. As I said earlier, I got 2 bad ones before I got a good one and it has happened to others on this forum.
The power steering system is self bleeding. The air will come to the top if the filling procedure was followed in the manual. IS your air pressure in the tires correect, if so and nobody messed around with the adjustment in the gear box, sounds like a bad control valve. Could be a bad pump, not building up enough pressure. Good luck.
I just had this same problem. I got a new valve from a reputable supplier back in January. No power steering. Got a replacement and finally got around to installing it today. Result, still no power steering.
Put the old stuff back on and everything works just fine. I think I will just deal with the slight leak.
Did you use the factory centering instructions on the valve or balance it with the cylinder attached to the frame bracket? The valve should always be balanced as described at the link below.
Make sure you have the hoses to the valve X'd. This is a common mistake and people sometimes assume the top hose on the valve is the top hose on the cylinder. I’m not saying you made this error but it never hurts to check! http://willcoxcorvette.com/repairand...lp.php?hID=129
I hate to say it, but if the system pass’s the above, I would lean toward the pump over the valve and cylinder. I can not remember the last defective new valve we had. I’m not saying it is impossible for the valve to be bad and it could be so lets not rule this out just yet.
Willcox Inc.
I`m going to put just the old valve back in, if it works that`s the problem. It is adjusted correctly. I`ll check the hoses, but I think they are on right. Thanks for any and all suggestions. It is very frusrating!
Try to explain this one. Old valve worked fine, just leaked.
Put new valve on centered it and it worked fine.
Had to make a right turn and with my foot on
the brake I tried to turn right, couldn't turn the wheel.
Took my foot off the brake it turned fine, so I tried it on a
left turn, foot on the brake worked fine, it only
happens when i'm turning right and putting pressure on
the brake petal
I have new tried two brand new valves with the same issue. Pump works fine with old valve. Hoses crossed, properly bled, properly balanced. New valve = no power assist at all. Only component changed.
Same exact stuff steering problem after new install
exact same thing just happened to me i, i put on new stuff and it’s worse than the old set up . I balanced it , belts and fluids are all perfect . Only things was the grease I’ll try that now
2016 C3 of Year Finalist
this is a very old thread, but you need to bleed the system. Try turning the wheel to the stops each way 10 times. And do not grease that zirq fitting. ITs for assembly only
