Bullet Door Mirrors
Old Jun 2, 2009 | 04:04 PM
76yellow's Avatar
76yellow
Default Bullet Door Mirrors
Has anyone put 78 to 82 bullet style mirrors on an earlier C3. If so,how did you about attaching them ?
Old Jun 3, 2009 | 12:05 AM
Steve COSD's Avatar
Steve COSD
Those mirrors have two threaded studs that when installed will be bolted inside the door. If you do get these type of mirrors make sure you get the correct plastic gasket that mounts between the mirror and the body. Also it is important how the gasket is oriented. If it is on wrong than the mirror will be very close to the glass. If you turn it 180 than it will be further away which is correct. I have a 82 with the mirrors you are speaking of.
Good Luck
Steve
Old Jun 3, 2009 | 08:41 AM
71rdster's Avatar
71rdster
You need the glass removed from the door to make this change. You will need to do some hole cutting in the sheet metal of the inner door to be able to put nuts on the studs for the mirror mounts, and to be able to get a socket on them. You will also need to remove your original mirror mount, and glass up the holes in the door where it was riveted.
Old Jun 3, 2009 | 09:07 AM
442olds's Avatar
442olds
Also before you go and pay a premium for "Corvette Bullet Mirrors" head over to the junk yard and pick up any long pedestal Bullet mirrors off of any other GM vehical. I know Delta 88's use the long pedestal Bullet mirrors. Then order the plastic gasket from Zips
http://www.zip-corvette.com/Zip/prod...612FFAD84187BD
Should save a ton of cash to get the look you want. You could even get a passenger side mirror with the extra long adjuster cable so you can mount it closer to the driver.
Old Jun 3, 2009 | 09:18 AM
76yellow's Avatar
76yellow
Thanks for the help guys !
Old Jun 3, 2009 | 09:25 AM
mtcraigco's Avatar
mtcraigco
Good Luck
Steve
Thanks! Now I know why my mirrors are so close to the glass and I can't see chit outta them!
Old Jun 3, 2009 | 11:25 AM
neuroclast's Avatar
neuroclast
Hrm... how close are they supposed to be? Mine are probably 3/4" from the glass. Is that normal??
Old Jun 3, 2009 | 11:42 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I have a pair of bullet mirrors, not painted yet, they are black and plastic.
They are GM of some type, Holler if your interested in them. 69VETT
Old Jun 3, 2009 | 11:48 AM
Ganey's Avatar
Ganey
Corvette put them on some 77s. Mine are original.
Old Jun 3, 2009 | 01:18 PM
Fast81's Avatar
Fast81
I have 2 DSide and 1 PSide that came with a project i recently picked up.
PM'd you
Old Jun 3, 2009 | 04:25 PM
tt 383's Avatar
tt 383
another option is the raydot bullets if you want a nice chrome race looking mirror.
Old Jun 3, 2009 | 05:44 PM
TPI BOY's Avatar
TPI BOY
To Bullet Door Mirrors
