What is this (under dash switch)?
Old Jun 2, 2009 | 06:32 PM
loquinho's Avatar
loquinho
Default What is this (under dash switch)?
1974 L48 Automatic
Ok, so the photo above is taken from the floorboard on the driver's side. I know the wiring looks like crap - in fact the headlights have been spliced in there somewhere, bypassing the headlight switch. But that's not important right now.
In the top right I have a pull switch that overrides the vacuum to the headlights. I don't exactly know why it's there, but I know what it does and that it works. In the top center of the photo, however, I have another switch, or something. This switch has a cable leaving the rear of it that appears to plug into the back of the speedometer, next to the speedometer cable. I have NO idea what this thing is. Or where it's supposed to be mounted correctly, for that matter. Who knows the answer to this one?
Old Jun 2, 2009 | 06:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This is your trip odometer reset cable! You push it in and turn it to reset the trip odometer.
Willcox
Old Jun 2, 2009 | 06:39 PM
Peterbuilt's Avatar
Peterbuilt
The pull down switch (the one with the vacuum hoses) will pop up the headlights without turning on the headlights.
Push and turn the other **** to reset your trip meter. PG.
Old Jun 2, 2009 | 06:42 PM
loquinho's Avatar
loquinho
Awesome, thanks guys. Now I just need to figure out how to anchor it back in place. I think it was removed when the power booster was being replaced.
Old Jun 2, 2009 | 06:53 PM
76yellow's Avatar
76yellow
It screws the the lower dash right below the ball vent right about where its hanging. If you look under there or feel there will be 2 stand-offs that it screws to.
To What is this (under dash switch)?
