Camber settings
Old Jun 2, 2009 | 08:12 PM
OMF's Avatar
OMF
Default Camber settings
The three references I have vary from 0 to + 1 3/4, with ranges between that. What is the prefered settings you guys like to use? This is on a '77 with some "spirited" driving on occasion
Old Jun 2, 2009 | 08:30 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IMCO, actually dialing your settings in more precisely than VB&P's recommended alignment specs which best describe your purposes is going to require some evealuation on your part. So, rather than speculate, I'd suggest selecting the appropriate baseline and to either leave it be or do some actual testing to determine if certain tweaks might yield an improvement. If you're really serious about this, you need a pyrometer (an IR will do in a pinch) and to learn how to properly read and quantify tire temps. Bottom line: Don't guess. My $.02
Of course, now you're going to hear from others how their setup is exactly what you need, but there are a lot of variables...
TSW
