Garcon, More power please!
Old Jun 3, 2009 | 03:39 PM
vettenoir's Avatar
vettenoir
Default Garcon, More power please!
I'm replacing (most of) the engine in my signature with the following:
- 409 SBC 10.3:1 CR
- 215cc Dart Pro I's - mild port, off the old engine
- Edelbrock Performer RPM, off the old engine
- C950, off the old engine
- CC XR280R solid roller cam - No, I don't mind adjusting lifters
I'm also thinking of getting more porting done on the heads.
How well matched is this setup?
How well do you think the power brakes & headlights will work?
Bob
Old Jun 3, 2009 | 06:04 PM
Little Mouse's Avatar
Little Mouse
I don't see you having any problems with brakes or headlights.
XR280R tight lash .016/.018, 242/248 .050, 2500 to 6500 ( based on a 350 ) 409 will bring the operating range down some. you have a 3000 stall not much for gearing. Should be nice torque in a 409 to help highway gearing 3 speed trans.
Old Jun 3, 2009 | 07:41 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Seems like the Performer RPM is your weak point. How do the ports line up with those Dart 215's? Everything else seems like a good match. I was going to do this with my tripower but it was expensive becase of the three carb mount points.
http://www.gethoned.com/process.html
Old Jun 4, 2009 | 10:54 PM
vettenoir's Avatar
vettenoir
Thanks for the replies. Not looking for super-high revs, but would like to make power to ~6500rpm. Camshaft decision isn't final yet. My engine builder is working with a Comp Cams design engineer (as opposed to tech guys that answer the phones & emails) I'll look into port-matchnig the intake & heads. The extrude honing process looks pretty cool. I'm always interested in new/different manufacturing processes.
Old Jun 4, 2009 | 11:10 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Port match intake to heads, XR286R is in my 427ci, great cam, here's a video of my previous 406ci with the XR280R @ 6500RPM making 550HP crank up the volume
Old Jun 8, 2009 | 10:41 AM
vettenoir's Avatar
vettenoir
Sounds great MotorHead. Can't wait to get mine installed!
Old Jun 8, 2009 | 12:49 PM
v2racing's Avatar
v2racing
vettenoir,
I have a brand new XR286R still in the box with all papers and cam card I would take $200 for if you are interested. It is the small base circle cam so you can run long rods in that 409 with it.
I was going to use it in my 406 but decided to do a custom grind.
Old Jun 10, 2009 | 05:05 PM
vettenoir's Avatar
vettenoir
Originally Posted by v2racing
vettenoir,
Thanks for the offer, but I finally decided on a custom grind that takes into account the different driving conditions for the car.
To Garcon, More power please!
