Just purchased a 1976 with 48k miles on it. My husband wants to add a little more power to it this winter and would like to know what a basic engine upgrade would give us a good boost in HP. We have the L48 with a 4 speed. I do not want to loose the original block and heads, but would like to know some basic ideas that we could do to increase the HP. (Bore size, cam, retooled heads, manifold, carburetor).
second, it is a little bouncy in the back end. What kind of shocks and should a new bushing set help with that?
Thanks for the help. I am excited to own the vette.
If you're concerned about originality, a good compromise is to store the original engine and drop in a crate.
If you're just looking for a little more oomph with the stock engine, the best power/$ is a cam upgrade. The L-48 cam is pretty mild (.390/.410 lift) and a modern cam in the .450 lift range will provide an excellent power increase for a pretty reasonable investment. Combined with an aftermarket dual-plane intake, carb and headers you've got a very solid and "seat of the pants" boost. I would not invest in porting the existing heads or going any further in terms of engine mods; you'll find a crate at that point to be more cost-effective.
Many answers here regarding shocks, spring replacement and other upgrades - my only suggestion is that you approach the suspension holistically as a system and not just do work to the rear.
A Vortec head swap with intake and a cam would work wonders on a basically stock engine. I know you wanted to keep the original heads, but just store them away for posterity. You can do searches for Vortec head swap and there is tons of info out there. Be careful on cam selection with Vortec heads, there are lift limitations. If you absolutely have to keep the original heads, then just a cam and intake swap will help. Bear in mind a cam swap without engine removal in an a/c C3 is not an easy job. Also changing to a high-flow catalytic converter will help too. The '76 has a pancake style converter that clogs pretty quickly.
A swap to TPI fuel injection is also quite a wakeup for a stock engine. Just a thought. I have it and I love it.
I would suggest also to swap your heads. I know you want to retain the "stockness" of the car but a set of aluminum heads with a combustion chamber size of 64 CC's will bump up the compression. Store the heads for the future should you sell it. A decent cam, aluminum heads, aluminum intake and the stock carb should put you at about 300 to 350 hp on pump gas
I appreciate all the ideas. This defiantly helps to see where we need to start. Up here in ND we have some very long winters so we will have lots of time to work on it.
