1977 Door Closing Problem
I am at the point after some adjustments and using lithium grease on every moving part of the locking mechanism, that I can close the door and it goes (from the outside) when I shut it, it grabs like a half a close. I then have to push it one more time (or one more click) and the door is closed. If I try to slam it from the inside it's a different story. It closes after a few slams. It should be easier.
I had the door panel off today and I had no weather stripping on the door. It closed every time perfectly. I put the new weather stripping on and this it is how it is now.
I was thinking about moving the striking pin out or the lock in a notch. But I then thought that it closed and aligned perfect on the second click, but I am having a hard time from the inside. It also closed perfect and aligned perfect (with no pressure on it) with the rubber stripping out. If I move the parts will it go in too far and be out of align? Any other advice?
Jack
Gary
