Sloppy Seconds, and Thirds
Old Jun 8, 2009 | 09:46 AM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
Default Sloppy Seconds, and Thirds
in a 69 auto car, the shifter is very sloppy shifting gears.
need to keep the original shifter, does anyone know if there is a look allike replacement or kit to make the original more drag race freindly ??
thanks !
Old Jun 8, 2009 | 10:06 AM
...Roger...'s Avatar
...Roger...
I've seen a couple temporary external devices that basically lay across the console to limit each shift.
Old Jun 8, 2009 | 01:17 PM
68/70Vette's Avatar
68/70Vette
Your shifter is probably just worn out. Volunteer Vette (forum sponsor) sells all the individual pieces for the muncie shifter. Also, you can still buy new shifters. The shifter is easy to rebuild by yourself, so you can just buy all the individual pieces from Volunteer and renew the one you have.
I pulled the shifter out of my 68, and the shift mechanism was hidden inside a big ball of grease and sand. Over the years, the sand had noticeably worn the pieces.
Before you take the shifter apart, take some pictures of it and maybe make some drawings. I didn't and to get it back together I had to get another Muncie shifter to look at to get mine back together!
Old Jun 8, 2009 | 01:39 PM
Donny Brass
thanks, but this is for an automatic......
Old Jun 8, 2009 | 07:29 PM
Donny Brass
anyone ??
Old Jun 8, 2009 | 07:39 PM
TimAT's Avatar
TimAT
Just about all the vendors have the detent plate and parts for auto shift cars. Figure out the parts you need and break out your credit card. really not that expensive either.
To Sloppy Seconds, and Thirds
