Generally, today's cams have the appropriate advance ground in. Advancing or retarding is not rebuild 101 stuff - the big change is where in the RPM range the engine makes power, but there are a number of side effects as well. Pick the right cam and install it straight up
And PLEASE don't install it anyplace but straight up without checking piston to valve clearance. Unless you're 100% positive you have loads of clearance. One way makes the intake valves closer the other way does the exhaust.
