Courtesy Light Timer - how long?
Old Jun 8, 2009 | 11:09 PM
PSU88's Avatar
PSU88
Default Courtesy Light Timer - how long?
Does anyone know approximately how long the delay is for the courtesy lights to go out after closing the door? I replaced the courtesy light timer and door-jamb switches, and ended up taking the courtesy bulbs out because the lights stayed on after closing the door....I forgot about the timer!
Any time estimates appreciated!
Bill
Old Jun 8, 2009 | 11:26 PM
blk79nj's Avatar
blk79nj
Mine are on for about 30 seconds. There is a way of disabling the timer, and make them function with doors only.
Somebody will chime in with the procedure.
Old Jun 8, 2009 | 11:27 PM
Goody's Avatar
Goody
30 seconds sounds about right.
Old Jun 9, 2009 | 10:09 AM
1nicecorvette's Avatar
1nicecorvette
tie the two white wires together. the domes will act as regular lights then . on with door open off with door closed. no timier effect! if you guys want a perfect alternative to the timer use this.
http://www.webelectricproducts.com/dome/dlddetails.htm
look to the left for dome light dimmer.
Old Jun 9, 2009 | 10:57 AM
PSU88's Avatar
PSU88
Thanks everyone! In my haste to trouble shoot once I got the battery back in, I didn't wait long enough for the timer to "time-out", and assumed I had a wiring issue. Just put the lights back in, and after waiting 35 seconds, they go out. Shew....one issue down, a few more to go...
Bill
To Courtesy Light Timer - how long?
