Ignition-Fuel mixture tuning....please step in
Old Jun 11, 2009 | 02:30 PM
corvette90's Avatar
corvette90
Default Ignition-Fuel mixture tuning....please step in
hi all
corresponding to this thread
http://forums.corvetteforum.com/c4-t...ny-needed.html
first, please let me give some specs on the engine
AFR 180cc heads, Airgap-Intake and a 224/230 110LSA comp cam (08-423-8), 750cfm speed demon carb..
the problem we have now is the following:
we adjusted the ignition to 10° at idle, with vacuum hose pulled.
the vacuum hose is connected to manifold vacuum (not to ported vacuum), the car seems to like it much more!
idle is very stable, car runs strong...
but..when cruising under light load at about 1800 rpm and get very slowly on the gas, some hesitation and bogging occur..we put a wideband O2 in, in this moment it jumps to about 20:1 AFR
after this hiccup the car is running normal
when stepping on the gas heavier at 1800 rpm, theres a small spike in AFR 20:1, but not enough to be noticed without Lambda Equipment.
the distributor, thats now in the car, is the stock dist. from a 350HO engine
can you give us some info how to cure the problem?
thank you very much
Old Jun 11, 2009 | 02:37 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Originally Posted by corvette90
hi all
thank you very much
Sounds like you don't have a pump shot at frist movement of the butterflies.
Old Jun 11, 2009 | 02:41 PM
corvette90's Avatar
corvette90
hi and thank you!
we thought about that, and we observed the moving of the pump arm very closely...it has no play in it, and starts to move with the very first movement of the throttle lever...
another thing..when the throttle is tipped in very slowly, so the pump shot is added very slowly, and maybe "not seen" by the engine, because, in comparison, the added fuel is not enrichening the incoming air enough..?
should we try different pump cams?
thanks
Old Jun 11, 2009 | 02:45 PM
Manuel Azevedo
hi and thank you!
thanks
Without the engine running you should see fuel at frist movement, if not fix the linkage so it does. Now if you have fuel after checking that then yes look for a cam that is more aggresive at frist movement.
To Ignition-Fuel mixture tuning....please step in
