1976 electical Issues
Alt= in working order
Battery Fully charged
Upon initial inspection I did noticed that the blade style conector on the top of the Alt. had its hot wire broke off, so I soldered and shrink tubed another one on, but the vehicle still doesnt have any power anywhere. Any help would be great and pictures would be awsome.
(704)394-5150 M-F 8:30-5:00 SAT 9:00ish - 4:00ish SUN 10:00ish - 2:00ish EST
"DUB"
Check it like the guys above described but if thats not it make sure your neg battery cable hasnt corroded off just under your battery bolted to the frame. One other thing to check is the 4 wire connector coming up from the starter -its between the firewall and right cylinder head of the engine-should have 2 red wires,a purple and a black-make sure its plugged together.
Now I am out of Ideas, I still have no power anyware on the vehicle. I dont know, which direction to go. I was told to take it in, but the towing fees, plus parts, plus labor for elec. work adds up quick. I was thinking of replacing the Engine Harness, Pos/Neg Battery Cables, and the Starter Selonoid extension wire. This would be every wire that comes off my Starter, exluding grounds. If any one has any better suggestions, I am open for your imput. If not those parts then its to the shop.
I wish I had a better wiring diagram (like one by Doc Rebuild) I think you might have another fusible link either on the left inner fender going to a junction block or it might be under the brake booster at the bulkhead connector-look for the large black connectors like the ones on the other links.
Got any good tips on replacing it, since it feed directly into the fuse block
It seems that there is another Fusible link in the same fuse box, but it is much smaller, i have not been able to locate what it attaches to, because it connects to a wire that goes back into a harness that is all wrapped up.
This weekend I will be doing "honey-do's", so I know I will not be in Saturday, but possibly Sunday. Either way, If you want call me and we can work out a time that is good for you.
If you choose to do this over the phone, have your tools handy. 12 volt test light, volt meter, screwdriver, sockets, etc.
"DUB"
Corvettes Etc.
4927 Wilkinson Blvd.
Charlotte NC 28208
(704) 394-5150 EST
M-F 8:30-5:00
SAT 9:00ish-4:00ish
SUN 10:00ish-2:00ish
I was driving my 76 corvette, and pulled up to an intersection, as I was going throught the intersection, everything, like some one turned off a light switch, went dead. I coasted throught the intersection, and tried to restart the car, nothing. I noticed upon inspection under the hood that the pig tail that connects to the top of the Alternator, had cam loose and the red wire was broke out of the back of the plastic conector. I thought this was the problem...
So here is a list of what I have done, all from suggestions of far better electrical guys than myself:
1. Replaced the Pigtail at the alt, and tested to make sure I had connectivity
2. Tested Starter at local autozone, tested fine
3. Replaced and tested both fusible links at starter, both are good
4. Tested both pos and neg batterycables, both tested fine
5. Checked every fuse in the fuse block below stering wheel, all fuses are good
6. Tested fusible link at dist block below mater cylinder, it also tested fine.
7. Tested battery, and it as well tested fine.
I dont know a lot about electrical, and only have basic knowledge of diagonosing such things, but I will put the starter back on in the morning (06 Sep 09) and hook the battery back up, for another go at testing everything, but as of right now I still have absolutly no power to the vehicle, none the lights dont work, it won't crank, it essentially is a giant paper weight, and I am starting to get frustrated.
VR
JR
