what is this hose??
<a href="http://s582.photobucket.com/albums/ss266/jsholm2/?action=view¤t=DSC01302.jpg" target="_blank"><img src="http://i582.photobucket.com/albums/ss266/jsholm2/DSC01302.jpg" border="0" alt="hose ??"></a>
http://i582.photobucket.com/albums/s...2/DSC01309.jpg
"DUB"
"DUB"
Thanks for the help guys. This forum is priceless
Grandmastercorvette is saying (hope I'm not insulting grandmaster) is the end of your hose that is not connected, the engine side, needs to be attached to a positive (sucking) vacume location.
The carb has different size connections that produce this requirement. As you can tell by the diameter of your hose, it needs to be a "large" connection. However, most of todays carb's do not have a separate connection for this Therfore, a common connection, know as a "t" from your carb to the PCV (postiive crankcase ventalation) hose will work.
I can't tell by your pictures if the PCV is in your left or right valve cover, but all you need to do is go to autozone or someplace like it, tell them you want to tie in to the pcv line with a common connection with another hose (tell them the size if your filter hose) and they should just walk down an isle and get you the plastic piece that will fit.
zmanc3
Your PVC hose from the carb should be at the front, down low, close to the intake manifold IN the base plate of the carb. That is if you still have a Qudrajet carb. I think some Holleys have it in the rear, but either carb, the hose connection will be the large (3/8" fitting) that is in the baseplate that is designed to allow you to slide and clamp a hose onto it. It is not a threaded fitting, much like your power brake booster connection, which is in the rear of your carb (if Quadrajat).
Once again, take the hose from the carb fitting and route it to your PVC. Install a vacuum "t" fitting into the hose. Now install a small section of hose to your "t" fitting and connect it to your PVC. Then connect your hose in question to the LAST port on the "t" fittting. Some PVC valves have a 90 degree end on them while some have a straight end on them , either way , just allow enough hose so the hose won't pull of or break the plastic end on the 90 degree PVC valve if that is what you have.
Be sure your valve covers are correctly installed as mentioned or you may have issues if not correct. Also if you do not have baffles in your covers, you may need to get new ones that have them. When you get the hoses correct. Crank your engine and test your PVC system. To make sure you have enough positive pressure, remove your breather tube or aftermarket breather filter. With the engine RUNNING and the PVC installed and connected. Take a small piece of paper that will cover the hole in the valve cover where the breather tube/filter was and place it over it. It should be sucked to the grommet and hold its position. Then drag it across is and see if you feel drag. If it is sucked to the grommet and has slight drag while pulling the paper across the grommet your PVC system is working correctly. If the paper blows off or will not stay, and yet you can remove the PVC while the engine is running and feel vacuum on the PVC valve by placing your finger tip over the end of the PVC valve, YOU have MAJOR engine issues dealing with the rings allowing cylinder compression entering the crankcase. Or try bypassing the hose you just connected and allow the hose from the carb baseplate to go DIRECTLY to your PVC valve and test again. You may have a bad charcoal canister if the results change for the better.
zmanc3...no offense taken.. bottom line here is to get it right and if I get offended by someone trying to help another by correcting me....well...I just need to get over it. I am GOOD, but I am not GOD. I learn something new everyday, or at least TRY to.
"DUB"
"DUB"
"DUB"
DUB:
That is exactly my spirit of this forum. Providing knowledge ,or at least my personal experience so others do not have to go down the learning curve road like I did. And read what others say about topics so I can learn from them; or better yet, have the comfort to ask a question and that question be received in an informative enviroment is all positive.
Respects:
zmanc3
Sorry if any complications were created from my error in typing.
"DUB"
"DUB"
"DUB"
