th350 help
Old Jun 14, 2009 | 09:09 PM
garretttpe's Avatar
garretttpe
Default th350 help
Hi
I have a 1980 stock vette, I just purchased a B&M transkit P/N 30229. while pre reading the instructions it says that it will not work on the TH-350C. According to the instructions if there is an electrical plug on the drivers side then the tranny is a TH-350C. I have an electrical plug with only 1 wire but it is a 2 pin plug. Does this mean that I do have a TH-350C lock-up converter and if so what P/N B&M transkit will I need.
Larry
Old Jun 14, 2009 | 09:20 PM
gingerbreadman1977's Avatar
gingerbreadman1977
sounds like you indeed have the TH350C .... if there is an electrical connection then it has the loc up. i think the 81,s came with a 4 pin plug.
i cant answer what part number you need for it but i hear the transgo kits are alot better then the B&M.
Old Jun 14, 2009 | 09:28 PM
jordan89's Avatar
jordan89
I think you do have the TH-350C. This happened to me when I was looking for a TH350 for my 78 camaro, I ended up buying a th350c and just ended up selling that one and bought a non lock up 350. I don't think they make shift kits for 350c, the only thing you might be able to do is install a B&M adjustable vac. modulator for like $28 and see if that works. The modulator works like a shift kit depending on how you adjust it, I have this and a manual/automatic valve body on my th350 in my camaro and it works great.
Old Jun 15, 2009 | 12:07 AM
7T1vette's Avatar
7T1vette
Call B&M and ask them if you can use that shift kit if you disconnect the lockup clutch. If so, you could put a manual switch on the lockup signal line and make sure that it is switched OFF when you want to "put the pedal to it", but leave it ON for normal driving. There could also be some "weak" area in the TH350C design that won't tolerate the harsher shifts of the shift kit. B&M should know.
Old Jun 15, 2009 | 01:06 AM
Grumpy 427's Avatar
Grumpy 427
I just had my tranny rebuilt, and the guy said there was a shift improver kit in the valve body, but wasnt sure which one was in it? He rebuilt it with the lock up intact. and i had the converter brought up to 1800-2000 stall and beefed up for the new motor 350hp and 390 tq.
To th350 help
