lower Radiator hose replacement!!!
Old Jun 15, 2009 | 07:03 PM
black15belt's Avatar
black15belt
Default lower Radiator hose replacement!!!
I recently took out the radiator hose from my dad's 71. Now that I have a new one I cannot get it completely in. Any tips??
Old Jun 15, 2009 | 07:10 PM
71_S-Ray's Avatar
71_S-Ray
you probably need to cut a couple inches off the radiator end of the hose. I just replaced my lower on my '71. it fit perfectly after a couple inches off. although the hose is 'made for your car', check the manufacturer's website on the part #. Goodyear uses the one I bought on several other cars; including an Olds Cutlass if I remember correctly.
Old Jun 15, 2009 | 07:47 PM
Duke94's Avatar
Duke94
You have the wrong hose or it's some kind of universal fit design. I'd take it back and get the correct GM hose from one of the Vette parts places or Chevy dealer.
Gary
Old Jun 15, 2009 | 08:43 PM
Roarinbear's Avatar
Roarinbear
I just got one from the Chevy dealer for my 75 and it was original and fit perfect.
Old Jun 15, 2009 | 08:48 PM
Goody's Avatar
Goody
Gary
There is some truth to this because I have a Carquest upper hose on my '81 that doesn't look anything like the other 80-82 pics I've seen up upper hoses. Generic GM that fits lots of trucks and such. Problem is it rubs on the upper alternator bracket and will not last too much longer. It is on my short list of things to do.
Lesson: if it doesn't look right, it ain't right.
Old Jun 15, 2009 | 09:06 PM
willem wallace's Avatar
willem wallace
Default Lower Radiator Hose
I was trying to locate the correct lower radiator hose for my 1971 small block. I have read that the correct hose contains a spring which prevents hose collapse on hard acceleration. Would anyone have advice on the best place to find this correct replacement hose, and a current part number.
Old Jun 16, 2009 | 10:19 AM
paks71's Avatar
paks71
Cruising
This is the Dad who owns the 71 vette in question. We think we have the 'correct' hose as we ordered it from Ecklers who is usually pretty good about these things. But it is worth checking. Hose is also bent severely as it comes around the fan shroud. Just doesn't seem right.
Despite the little problems, its been a great father/son (and two other sons) project this summer.
Old Jun 16, 2009 | 10:55 AM
Mashman's Avatar
Mashman
I replaced the hoses on my 72 sb earlier this year.
The lower hose was a complete PITA! The problem is that it's very hard to gain any leverage to get the darn thing on.
I use a little dishwashing soap on the inside of the hose, and was able to get mostly on from the bottom, and then twisting and pushing got it on all the way from the top. I've heard of others that have heated the hose up with hot water to make it softer and easier to put on - but I was doing this by myself, and figured that appoach would be harder, but with 2 people that might be the easier way to go.
Do you have AC? The bend may be to clear the AC compressor belt - mine has AC, so it fits/looks very natural to me.
Matt
Old Jun 16, 2009 | 11:11 AM
black15belt
Maybe it is jjust a process that will take much time. We are finishing it up today. For a lubercant i have been using wd-40 to get other hoses on and it has worked quite well/
Old Jun 16, 2009 | 11:16 AM
7T1vette's Avatar
7T1vette
Make certain that you don't have the hose install 'upside-down'; the length from the bend is different on one end than the other. Also, Install the radiator end first, as that end is the most difficult one to engage. Then install the pump end.
Old Jun 16, 2009 | 11:33 AM
bashcraft's Avatar
bashcraft
Antifreeze works well as a lubricant.
Old Jun 16, 2009 | 11:47 AM
greg75vette's Avatar
greg75vette
Straight up pure antifreeze is some slick stuff. Take a rag and wet it, rub inside the hose and around the connection. Slides on like a dream.
Furthermore, I had a real corvette hose that I had to trim as well. I had to trim it at the water pump though. If I didn't, the extra length pushed into that first severe bend and kinked the hose.
I would try lubing the hose first, then if that doesn't solve it, cut a 1/2" at a time.
Old Jun 16, 2009 | 12:35 PM
Duke94's Avatar
Duke94
Here's what I believe to be the correct lower hose on my 71' (GM part number 3917669) Never trimed it, and appears to fit correctly. Bought it from ZIP a couple years ago.
Gary
Old Jun 16, 2009 | 02:59 PM
paks71's Avatar
paks71
Cruising
Duke94, great pic, thanks!
This is what our hose and engine/radiator seems to look like, but our view is much more obstruced by ac compressor and larger fan shroud. Perhaps my fan/shroud are larger due to a/c (and auto tranny) because the space between the shroud, upper control arm is much much less than in your pic. In your pic, the view of the hose from the upper control arm forward is completely blocked by the fan shroud.
I wonder if my radiator for the transmissions requires engine radiator to be mounted differently (closer to engine), meaning a hose for a non-AC, manual trans would be different than for with a/c and auto.
-pak
Old Jun 16, 2009 | 03:54 PM
Duke94's Avatar
Duke94
Here's the partnumbers for lower rad hoses. Looks like hoses are different depending on options.
Gary.
Old Jun 16, 2009 | 09:07 PM
markey mark's Avatar
markey mark
Don't know about the fit of the hose but dishwashing soap is by far the best install lube.
Old Jun 22, 2009 | 10:22 AM
paks71's Avatar
paks71
Cruising
Thanks to all for your help! We finally got the hose installed. It was just a real pain due to the tight space between upper control arm and fan shroud. This was one of the final steps for restarting the engine. We fired her up last week for the first time in 13 years, runs a little rough, but apparently no major problems. The car hasn't been driven in 18 years, so we still have lots of work to do. Next project is brakes.
To lower Radiator hose replacement!!!
