Help! Exhaust removal (pics)
Old Jun 16, 2009 | 08:06 PM
bernie payne's Avatar
bernie payne
Default Help! Exhaust removal (pics)
I am in the process of taking out the rear differential, and one of the first things to get out of the way is the exhaust pipes. I have everything unbolted, but can not get the pipe to slide out here. What should I do?
I tried using a torch to heat the outside pipe, but it doesn't want to budge.
Old Jun 16, 2009 | 08:49 PM
Goody's Avatar
Goody
Given the current state of things, I would just cut it off as close to the end as possible and then have flanges welded on by a muffler shop so you don't have to do this ever again.
Old Jun 16, 2009 | 08:57 PM
Oldguard 7's Avatar
Oldguard 7
Yup, buy a pipe cutter (hand held) and cut it off. That is what I did when I removed my diff several years ago.
Old Jun 16, 2009 | 09:34 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Why take it apart so far forward?
Assuming you still have a factory catalytic convertor and rear Y pipe, why not disconnect at the rear of the convertor and drop the muffler assembly as one big piece? 4 bolts at the convertor, cut em off or snap them off if they won't unscrew.
Old Jun 16, 2009 | 10:18 PM
bernie payne
I wish it was like this. Bubba got to it somewhere in the cars life, and just decided to weld everything. Behind this everything is all one piece.
Old Jun 16, 2009 | 11:19 PM
dstaley's Avatar
dstaley
heh, I rarely have trouble taking stuff apart, it's putting it back together that gets me in trouble!
You could just cut it where the pipe is nice and straight, because a splice piece from the local auto parts store would easily rejoin the cut in a simple location like that. It would also be easy for a muffler shop to reweld a cut between two pieces that only have to be straight.
Old Jun 17, 2009 | 11:17 AM
bernie payne
Good thinking. I will probably do something like this. Unless I can afford the x pipe set up when I get done with the rear differential. I have my headers, just need new pipes.
Old Jun 17, 2009 | 09:19 PM
PRNDL's Avatar
PRNDL
you might be able to loosen it up with a generous application of PBBlaster and wait a few hours. If you are twisting and pulling on it be very very careful not to pull the car off the jack stands onto yourself... on second thought, just cut the damn thing off!!
although.. it did work for me. and I have the same Harbor Freight jackstands too!
Old Jun 17, 2009 | 09:52 PM
bernie payne
I am actually going to harbor freight tomorrow to buy a sawzall and cut it out.
I was surprised about the jack stands, they are pretty nice.
Old Jun 18, 2009 | 12:30 AM
rajsid's Avatar
rajsid
That was what I ended up doing after days of muscling with the old rust locked exhaust.
Old Jun 18, 2009 | 10:25 AM
7T1vette's Avatar
7T1vette
Many years ago I used to 'fight' with exhaust systems. Now, I just cut 'em off. (sawz-all or cut-off wheel).
If you want to save the pipes, just cut the muffler entry pipe ahead of the joint.
Old Jun 18, 2009 | 12:17 PM
mtcraigco's Avatar
mtcraigco
Sawzall time!
I JUST had this fight a week ago and it felt GGOOOOOODDD to cut that mudda in two!
+1 and having it put back in with flanges!
To Help! Exhaust removal (pics)
