Block Plate
Old Jun 17, 2009 | 10:21 PM
fantic's Avatar
fantic
Default Block Plate
How many guys use the block plate that comes with their bellhousing? I know it is good insurance but also a pain in the a$$. It's going in a street car.
Old Jun 17, 2009 | 10:39 PM
Mad Vette's Avatar
Mad Vette
Do you mean the almost half circle plate the covers the lower portion of the bell-housing? That's important to keep dirt and road debris from getting into the clutch and starter.
Old Jun 17, 2009 | 10:45 PM
fantic's Avatar
fantic
I'm talking about the full one that comes with a Lakewood bell housing.
Old Jun 17, 2009 | 10:50 PM
Hadez's Avatar
Hadez
its installed on my car
Old Jun 18, 2009 | 12:40 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Always use it. The whole point is to contain an explosion and the plate can help do that and maybe even save the block.
What problem are you having? Shouldn't be any issues.
JIM
Old Jun 18, 2009 | 11:52 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Use the plate.
Not using the plate will change your tranny geometry,
by about 1/4" further into the crank.
which could change many things, like clutch linkage, throwout bearing,
your gear shift rod alignment, and even your driveshaft engagement.
there is not 1 reason not to use the plate. 69VETT
Old Jun 18, 2009 | 01:10 PM
midyearvette's Avatar
midyearvette
Originally Posted by 69Vett
Use the plate.
Old Jun 18, 2009 | 05:54 PM
jackson's Avatar
jackson
You can buy new LW BH without the plate ... sometimes referred to as a "clutch can."
Old Jun 18, 2009 | 06:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Yes, absolutely use the plate.
Old Jun 18, 2009 | 06:46 PM
L88Plus's Avatar
L88Plus
Use the plate.
It may change it a bit, but not 1/4" - these steel block protectors aren't but about .75 - .100 or so thick.
I'd trial fit it, it could save your block in the event of a tranny grenading.
BTW, most of the searches I've done lean towards the McLeod since it's easier to align.
Old Jun 18, 2009 | 07:10 PM
fantic's Avatar
fantic
I didn't think about the thickness of the plate. I measured the stock bellhousing and it is 6.25 inches. The lakewood is a hair deeper than that. The block plate is .125. Together the Lakewood and block plate is almost 6.5 inches. So it would put the tranny out .25 inches farther than stock. By the way the Lakewood was out .006 inch first try. The stock was out .013.
Old Jun 18, 2009 | 07:12 PM
Big Block 69's Avatar
Big Block 69
Default Block Plate
My Lakewood came with one and I used it. The only issue was taking off the flywheel, but you only have to do it once then it's DONE!
You'll be glad you did it.
To Block Plate
