need some R12-help
Old Jun 20, 2009 | 12:49 AM
LT1driver's Avatar
LT1driver
Default need some R12-help
where can I get some R12 for my airco, not cold but blowing cool as it has been sitting awhile with broke tranny. anyone got a can they want to sell me in the DFW area or know where I can buy, don't have a license yet but will someday maybe. PM me if you can help. thanks.
Old Jun 20, 2009 | 01:09 AM
Peterbuilt's Avatar
Peterbuilt
Default Any other options?
Had my A/C repaired 5 years ago and R-12 cost $65.00 a pound then, seems like no one has it any more. My A/C gets cold for 5 minutes and then quits blowing cold air. I looked at the sight glass and it seems like fluid is flowing but the A/c sure is not good enough. I'm not sure what they mean when they say "Do you see bubbles" in the sight glass, seems to me like there is fluid flowing? I have no clue about A/C, can someone suggest anything else that can be used?
Thanks, PG.
Old Jun 20, 2009 | 02:37 AM
bowtie350_428's Avatar
bowtie350_428
I have seen cans of R-12 on fleabay. You don't need a license to pruchase if its for "resale".
Old Jun 20, 2009 | 09:26 AM
mark79,80's Avatar
mark79,80
Below is a link where freon r 12 can be purchased. I have used
them several times a few years ago and received quick delivery.
You do need a certificate to purchase it but that can be obtained
by taking a test on line which was not difficult.
http://refrigerantsales.net/shop/ind...ndex&cPath=1_5
Here is a link for the test:
http://www.epatest.com/609/
Old Jun 20, 2009 | 12:38 PM
1911fool's Avatar
1911fool
There is something called Freeze-12 that you can use.
Old Jun 20, 2009 | 12:41 PM
oldboat's Avatar
oldboat
i buy it on ebay or at the goodguys car show. there are usually several people selling r12 at the swap meet at the goodguys shows. i pay between twenty and thirty dollars a can.
Old Jun 20, 2009 | 12:57 PM
mrvette's Avatar
mrvette
Bad enough paying ten bux/can for 134, and it's next door to boot....
better to change over the system once and for all, and if you make up your own valve for the cans, you can find a brass fitting to adapt the can to your R12 gauges, and then sweat it into the 134 valve, and have done with it...just know you need about 20 lbs on the suction side with 134, and sometimes you need to get that 134 good and hot in order to get the second can into the system....I use a propane torch, judiciously but it works well, pass it over the outside of the can with system running, can upright into lo/suction side and it fills in a hurry....
do NOT severely overheat can as to burn the paint off,
an a/c mechanic will put it in water, or hot water, hell, all you need is heat the can...so use the torch, much easier and faster too...
Old Jun 20, 2009 | 01:46 PM
mailbox1024's Avatar
mailbox1024
I know i have at least 1 or maybe 2 cans of R-12 in my garage if your interested. Let me know...Ron
Old Jun 20, 2009 | 03:36 PM
Peterbuilt's Avatar
Peterbuilt
Seems like Freeze 12 is a good alternative, thanks for the tip! PG.
Old Jun 20, 2009 | 03:44 PM
71 Green 454's Avatar
71 Green 454
Has anyone on here used Freeze 12 as a direct R12 replacement like the Freeze 12 website states?
Old Jun 20, 2009 | 08:08 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Last week at my local NAPA R134 was 4.99 a can
Old Jun 20, 2009 | 08:57 PM
markdtn's Avatar
markdtn
Stay away from that stuff, just stay with R12 or convert to R134. Freeze 12 is mostly butane. Do you really want pressurized butane in your engine compartment?
R12 is still out there. I have 2 virgin 25lb cylinders I'll gladly sell to the first $300 each or $550 for both. I would have to see a liscence, but you can get one for like $30 and an open book test.
To need some R12-help
