Valve cover bolts-Stud type ??
from Wintery Melbourne (Australia),
I just bought new valve cover bolts(stud type)
and I'm not sure what is the best way to install
them
.Do I...
1/ use 2 nuts to put them into the head
(and if so how far/tight)?
2/ just leave the threaded part in the chrome
nut and use it like a bolt ??
Also should I use Locktite on them ??
(on the stud into the head part not the nut).
I hope to do this early in the morning
so I can take the wife out cruzing & picture taking
(without the smell burning oil filling the cabin
).Any hints or tips gratefully accepted.
Gavin
Double nut the studs in if needed and use Locktite.
If your using the standard stamped steel valve covers you need to use rvt instead of gaskets or use the spreaders on each of the 4 bolts.
... I followed this procedure and did not use loctite. No issues! I like them!
So no probs with the install.
Thanks for the tips etc.
Now to fire her up & check for leaks.
I also decided to check my EGR and surprise, surprise
It wasn't working.I tested it with a vacuum
pump and the diaphragm didn't move or hold vacuum.
So I've blocked it off 'til I can afford/find another.
CHEERS
GAV
No RTV used, just the gasket with the bolts snugged to 45in/lbs.
I left EGR in place but not connected to vacuum
and noticed my exhaust "popping" has gone.
So that solves that puzzle (vacuum leak from EGR).
I cant seem to find the same EGR on Feebay or any of the Vette
vendors sites, they have others but numbers dont match mine.
The one I have is marked
Rochester-MT 7040299 28231
(Could be a bastardization done here in Australia).
It just started raining so no test drive today
Again THANKS to eveyone for their HELP & patience.
CHEERS
Gav
