Engine Swap?
Old Jun 20, 2009 | 10:42 PM
X Man's Avatar
X Man
Default Engine Swap?
Hi All
The motor in my 1980 L82 broke the crank!
A friend has a TBI 350 from a 1986 Chevy Blazer that I can have to put in my car till I can afford to get my motor fixed.
My question is will the intake from my L82 fit the other motor? Has anyone done this before.........will the swap work?
Old Jun 21, 2009 | 09:51 AM
X Man's Avatar
X Man
Has no one ever done a TBI/Carb swap?
Old Jun 21, 2009 | 10:07 AM
midyearvette's Avatar
midyearvette
Originally Posted by X Man
Hi All
i dont think your intake will work but i could be wrong.....do some research on the cylinder head intake gaskets....i think they are different....thats when you had tuned port and also tbi and i believe the bolt patterns were changed from earlier engines.....good luck
Old Jun 21, 2009 | 04:48 PM
X Man's Avatar
X Man
Could the throttle body be removed and replaced with a carb?
Old Jun 21, 2009 | 10:07 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Are you sure its an '86? From my memory, '87 was the first year for TBI on Chevy trucks.
It also seems like they used an adapter to mount the TBI unit onto a carbed intake.
This is all from memory though, and its been many years since I have looked an an engine from that time.
Old Jun 21, 2009 | 10:36 PM
69elky's Avatar
69elky
Default bolts
As Driveshaft stated,87 was the first year for throttle body injection.If you have an 86 engine you should be good with bolting up to your excisting manifold.The TBI bolt pattern is different only by the angle of the bolts,carb manifold still has an angle to the heads pattern and TBI is almost flat manifold to the heads.As for the 87 you could always use your heads if needed.
Old Jun 22, 2009 | 02:07 AM
killer454's Avatar
killer454
im doing this right now with a 1986 corvette block (one piece rear seal) going into my 1980 vett with a 1972 cast-iron intake and quadrajet carb.
got my engine together but i still need to order my flywheel for a 1986 block and starter and torkconverter for a 1980 turbo 350.
It will work im doing right now
To Engine Swap?
