Head Question...
Old Jun 21, 2009 | 08:20 AM
DO2G's Avatar
DO2G
Default Head Question...
I'm considering buying a pair of Brodix IK180. They sell 2 versions. Can someone help me understand the difference and let me know which one you would recommend for a L82 4 sp, true dual exhaust, performer intake. Everything else is stock.
http://www.summitracing.com/parts/BRO-1021004/
http://www.summitracing.com/parts/BRO-1021005/
Old Jun 21, 2009 | 09:04 AM
Ganey's Avatar
Ganey
Valve springs are different.
The Brodix are avail. in 64cc or 70cc. Stock L-82 is 76cc, so order the 70cc which will increase C/R.
Old Jun 21, 2009 | 02:25 PM
TopGunn's Avatar
TopGunn
The 1021005 has .575 lift vs .524
Old Jun 21, 2009 | 03:37 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If you are planning to keep the L82 cam, the first part number would be appropriate.
The spring specs per Brodix are-
1.250 Hydraulic Valve Spring - CC 981,
100 lb Closed, 300 lb Open,
1.850 Installed Height,
.525 Maximum Lift
or
1.470 Hydraulic Roller Valve Spring - CC 987,
125 lb Closed, 325 lb Open,
1.900 Installed Height,
.575 Maximum Lift
Old Jun 22, 2009 | 12:18 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I would go with the 64 CC heads. The L82 cam will have no problem with the extra compression.
To Head Question...
