View Poll Results: Vote on my gear ratio
3.55
14
36.84%
3.70
18
47.37%
You're an idiot - install OD & 4.11
6
15.79%
Voters: 38. You may not vote on this poll
Gear Ratio Question
Old Jun 21, 2009 | 10:27 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Gear Ratio Question
Street car - 396sbc, near 500hp, TH400 tranny. New suspension front & back. Considering a new ratio as Bubba decided he needed better gas mileage. He put a 3.08 in 3.55 pumpkin & I bet he never re-couped. Car is not currently drivable so I don't know how the current combination will work out, but I don't need to go 140. This will be a weekend cruiser.
Sorry about the poll, been spending too much time in OT
Old Jun 21, 2009 | 10:41 AM
L79racer's Avatar
L79racer
For a weekend cruiser if your not planning long trips I would go with at least a 3.70. 4.10 would be killer for a few blasts light to light!
Old Jun 21, 2009 | 10:45 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
3.70's are plenty low enough. Any lower and all you will be doing is frazzeling the tires. It will still allow you to run down a couple of exits on the interstate if you decide to.
Old Jun 21, 2009 | 12:09 PM
Disco_Mike's Avatar
Disco_Mike
what are the stock gears for 79 L82 4speed?
Old Jun 21, 2009 | 01:58 PM
C3 Stroker's Avatar
C3 Stroker
With a 500 HP SBC you're obviously performance minded, so if you want the quickest bang for the buck go with 4.10's.
Old Jun 21, 2009 | 06:48 PM
gingerbreadman1977's Avatar
gingerbreadman1977
i like 3.55 for intermediate - good for some highway and good accellaration.3.70 a good choice but you might be bouncing around the joint on take off. 4.10 forget the hiway .
500 hp would push any gears just fine so unless your doing strip i would stick with 3.55 and they will be smoking 1st and 2nd to shreds anyway
Old Jun 21, 2009 | 10:48 PM
ratflinger's Avatar
ratflinger
In 79 you could get a 3.36, 355, or 3.70. 3.55 was std w/auto, so I'm guessing the 3.70 was the optional for the 4-speed.
Old Jun 21, 2009 | 11:38 PM
FRSTR90's Avatar
FRSTR90
3.55. The only difference one will feel between a 3.55 and a 3.70 is at the pump. 3.55 and 3.70 are so close together, you wont notice the added power with the 3.70.
Old Jun 21, 2009 | 11:46 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Is this a HR motor? How big is cam? What's max RPM for it? How much hwy driving? What converter?
JIM
Old Jun 22, 2009 | 01:22 AM
GR879SHARK's Avatar
GR879SHARK
I like the 3.70 but as said before you won't notice the diff with the 3.55 and 3.70 without sticky tires you will be cooking them either way!!!
Old Jun 22, 2009 | 09:17 AM
Rally68's Avatar
Rally68
I just changed my '68 SB from the stock 3.08s to 3.73s. Mine is a weekend cruiser also, 327/300 THM400. I've seen a similar poll in an earlier thread and the 3.70 ratio was the clear winner. Not sure what percentage of voters in the earlier poll were putting out 500HP, though
I haven't driven mine yet, still installing the new rear suspension. I suspect there will be times I wish I had an overdrive, but with my (old, original, tired) 327 I wanted the torque.
Old Jun 22, 2009 | 09:30 AM
steved400's Avatar
steved400
3.55 work great with the BB; 3.70 might be better with a SB, 4.11 takes all the fun out of any highway driving.
Old Jun 22, 2009 | 11:27 AM
shmoky's Avatar
shmoky
I'm running a BB with around 425RWHP and 3.70 gears (munsie 4spd). Great for running around town but at 60 mph I'm at 2900rpm with 255/60/15 tires on the back end. I don't know what the difference with the auto would be. I'm thinking of going to 3.08 if I don't get a TKO 5spd.
shmoky
Old Jun 23, 2009 | 09:48 AM
gkull's Avatar
gkull
The more power you have the less gear you need. I'd drive it around with a 3.08 and see how you like it.
To Gear Ratio Question
