autofab 4 link
Old Jun 22, 2009 | 06:58 PM
L79racer's Avatar
L79racer
Default autofab 4 link
Here is a few pictures of my new set up. Still got a few thing to do but its on the ground. I will be cutting the front springs to lower the front.
It has a 29x11.5 Hoosier quick time pro on it with a 8.5 wide rim with a 4 7/8 backspace. I did modify the chassis a little. I had to cut open the rear tube for clearance for the ride height I wanted.
Old Jun 22, 2009 | 08:24 PM
JoeC427's Avatar
JoeC427
Nice
12 Bolt looks good under there.
Did you modify the frame rail to fit that tire?
Old Jun 22, 2009 | 09:45 PM
bluzman2004's Avatar
bluzman2004
Nice fitment of the tire. They look right on their and it sits good, too.
Do you have a pic of the frame mod you did?
Very
Old Jun 22, 2009 | 11:02 PM
L79racer's Avatar
L79racer
Originally Posted by JoeC427
Nice
Yes I did. I removed the double thick support that is next to the opening of the trailing arm hole. I then bang in the frame rail before I closed the hole up with the metal plate that come with the kit. Just got my moser girdle cover for the 12 bolt today. I just had that old cover to throw on until I got the new one. A 12 bolt looks bad *** under a Vette.
Old Jun 22, 2009 | 11:06 PM
L79racer's Avatar
L79racer
Very
I'll try and get a few pictures of the mod in a couple of days, this week is very busy with work and my sons sports teams. Basketball and baseball.
Old Jun 23, 2009 | 10:05 PM
L79racer's Avatar
L79racer
Here are a few more pictures. I'm pointing to where a modified the chassis for a tall tire.
Old Jun 23, 2009 | 10:25 PM
bluzman2004
That looks great! I'm going to have to remove that double piece, too.
One question, I see your track bar is mounted on the front of the drivers side frame slanting to passenger side. Mine is the other way, and I've seen picts for both ways. What made you choose that way?
Old Jun 23, 2009 | 10:43 PM
L79racer's Avatar
L79racer
I dont think it matters at all. I had it that way on my vega so I just did it the same.
Old Jun 23, 2009 | 10:48 PM
CorvetteDave01's Avatar
CorvetteDave01
Very nice man! Those 11.5" tires look great
How much space do you have between the frame and the tire? What do you think you need when you lower the tire pressure?
Get us some more pics of the rearend with the new cover man.
Old Jun 23, 2009 | 10:53 PM
CorvetteDave01
What kind of axles and posi?
Old Jun 23, 2009 | 11:08 PM
L79racer's Avatar
L79racer
It is very close to the side of the frame. I might put a small spacer on it just to be safe. I'm thinking of trying a 10" rim and that would bring it away from the chassis also but it would bring it out past the whell well lip more than I have now. I have a Moser 33 spline spool and axles. I'll post more pictures once the new cover is on.
Old Jun 25, 2009 | 05:25 PM
bluzman2004
What #lb springs did you end up starting with? I think the only real changes I might need to is change spring rates to get it exactly where I would like it. I think I might need a little higher rate than the 150# I have now. Or, maybe less, who knows.
Old Jun 25, 2009 | 09:19 PM
L79racer's Avatar
L79racer
I went with the 150lb springs after talking to Josh. These are the springs he recommended. I thought they might be too stiff. A 4 link car should have the softest spring possible. The spring should just hold the car at ride height. I have mine set that the shock is 12" center to center. That leaves 2" of compression and 1 1/2" for extension. As long as the springs dont coil bind on compression were good to go. My vega that weighed in at 2800lbs had 95lb springs. It did use a longer shock than the vette shock. Thats why they us a stiffer spring for the lesser shock travel.
Old Jun 25, 2009 | 09:54 PM
CorvetteDave01
I think I ordered 170# springs because I was worried about the tire hitting. I guess I can go lighter later if needed, they shouldn't cost too much.
Old Jun 26, 2009 | 09:34 AM
bluzman2004
Yeah the springs are only $70 for a pair. Remember Dave the bottom bracket is adjustable, so you can set you shocks at the correct length and then use the bottom brackets to move your ride height.
I called QA1 and gave them my rear weight (1728lb) and they suggested I needed 200lb
At the track it hooked great with the springs just a very little preloaded, not much at all, but I didn't measure them, but this only gave me 1" of compression left in the shock. I set the shocks on 3.
Old Jun 26, 2009 | 02:02 PM
L79racer's Avatar
L79racer
Ron, what did you use for brake lines from the original blocks to the new calipers?
Old Jun 26, 2009 | 04:17 PM
bluzman2004
I ordered the fittings to convert to AN-3 or -4? and braided lines to match with one side a right angle. Speedwaymotors had the stuff. It made it real easy to run my line out of the way.
www.speedwaymotors.com
Lines: 91031893
Fittings: 6174031
To autofab 4 link
Old Jun 26, 2009 | 10:23 PM
L79racer's Avatar
L79racer
Ron, did you mount your calipers on the front side or the rear side of the rotor? Does it make a difference if they are on the front or rear? I think I want to mount them on the front side.
Old Jun 26, 2009 | 10:41 PM
bluzman2004
I don't think it would make a difference. Just make sure your bleeder screw is pointed up. I mounted mine on the rear just so I could get to the 4 link bars and hyme joints easy. I will say it comes close the spring coils in the back though. Doesn't touch, but close.
Old Jun 26, 2009 | 11:19 PM
CorvetteDave01
More pics please! Especially with the new diff cover.
