cam specs
Old Jun 23, 2009 | 11:35 AM
robC-1965's Avatar
robC-1965
Default cam specs
Does anyone know what the factory specs are for the cam in a 78 350 vette? Or better yet where this type of information can be found.?
Old Jun 23, 2009 | 12:13 PM
Scott Marzahl's Avatar
Scott Marzahl
78 L48 or L82?
3896929 Hyd. - 194/202 - .390/.410 - 112 - L48
3896962 Hyd. - 224/224 - .450/.460 - 114 - 350 L-46, L-82
Old Jun 23, 2009 | 02:39 PM
PAmotorman's Avatar
PAmotorman
3896929 cam dur @ .050 195/202, lobe sep,112,open/close@.050(10.5) 25.5 int,37(15) exh,lift .390/.410
Old Jun 25, 2009 | 03:53 PM
robC-1965's Avatar
robC-1965
I do have an L48 - I would like to give it some more power. Trying to figure out what to use with the factory quadrajet, and a set of vortec heads, blackjack headers and dual exhaust less cat and nobalance tube.. Need to decide on an intake, cam & lifters, timing gears, etc.. I am during all the work myself just don't know a lot about what to us to get the desired finished product, with in the budget.. Car will be driven, especially on nice days.
Old Jun 25, 2009 | 06:54 PM
billla's Avatar
billla
St. Jude Donor '14
For future reference:
http://www.geocities.com/MotorCity/D...00/cmspec.html
Budget is the key word - with that I'd be happy to offer some guidance.
Old Jun 25, 2009 | 08:46 PM
Scott Marzahl
Well thats not too bad. You are kind of limited to either a Performer or Weiand 8004 intake. I'd use a set of Cloyes street roller gears and an either an Engle Cams 1015H or 1018H depending what your Vortecs can handle for lift and where you want your power band, driving style etc. The 1018H is a real nice cam with 9.25-9.75:1
Part #: 1015-H
Grind #: EP-15/18HY Int. 437"
Ex. 458" Int. 248"
Ex. 260" Int. 291"
Ex. 310" Int. 207"
Ex. 216" 112°
Part #: 1018-H
Grind #: EP-18/20HY Int. 458"
Ex. 468" Int. 260"
Ex. 268" Int. 305"
Ex. 310" Int. 216"
Ex. 226" 112°
Old Jun 26, 2009 | 09:30 AM
robC-1965's Avatar
robC-1965
Roller gears - is that an all gear set up, no chain?
Are cams all that confusing?
Old Jun 26, 2009 | 09:41 AM
Ganey's Avatar
Ganey
It has a chain. Roller timing set was meant above.
At least Trans. should be stated for cam.
Old Jun 26, 2009 | 10:36 AM
robC-1965's Avatar
robC-1965
Roller timing set - is that a set that is all gears or a type of chain set?
Next question has I am trying to piece this together - looking at edelbrock intakes - Is the quadrajet a square bore? What is the difference?
Old Jun 26, 2009 | 10:58 AM
jackson's Avatar
jackson
78 L48 w/ vortec heads
cam w/ lifters: summit sum-K1103
head gasket: felpro 1094
intake: professional products 52007
any timing set will do OK ... no need to spend lots here ... stock lasted a long time ... vortec has about same spring pressure as L48 ... most any cam that works with L48 piston & vortec chamber will be relatively mild ... K1103 is & works w/ any trans-gears
Old Jun 26, 2009 | 10:59 AM
Ganey's Avatar
Ganey
Chain set. Q-J is spreadbore, small primarys & large secondarys.
oO
oO
Squarebore has 4 same size.
OO
OO
Old Jun 26, 2009 | 12:05 PM
robC-1965's Avatar
robC-1965
oO
oO
OO
OO
Thanks changes the intake I picked
Old Jun 26, 2009 | 12:32 PM
robC-1965's Avatar
robC-1965
Okay here's what I got so far - What do you all think?
Comp Cam: 12-210-2
Comp High energy Hydraulic lifters: 249-812-16
Edelbrock performer Intake: 2116
Jegs Queit timing gears: 555-20310
Comp magnum roller lifters w/ p. rods: 249RP1412-16
all these items were found on Jegs
Any other suggestions? Am I missing anything?
Old Jun 26, 2009 | 02:07 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Comp Cam: 12-210-2
If this is a budget build, why are you planning to buy a gear drive?
Old Jun 26, 2009 | 02:13 PM
robC-1965's Avatar
robC-1965
They just seem to make since - Still tossing the chain around because of the money.
Old Jun 26, 2009 | 02:22 PM
DRIVESHAFT's Avatar
DRIVESHAFT
You will spend $100 more than you need to with a gear drive.
A timing chain like this one http://www.summitracing.com/parts/CLO-C3023/
is completely capable of handling your needs, and it wont make an annoying whining sound either.
Old Jun 28, 2009 | 09:28 AM
billla's Avatar
billla
St. Jude Donor '14
I have to admit to some surprise that any recommendations can be made with no budget. Vortecs are GREAT budget heads...but they are budget heads, with more power to be found with better heads...all determined by the budget. If existing heads, then a spring swap may be the first step.
There's absolutely no reason to run a gear drive on the street - regardless of the advertising hype. I'm also not a fan of roller (even roller-tip) rockers for a mild street engine, but there's no reason NOT to. However, those rockers are not self-aligning, which are required for Vortec heads.
An important consideration is the head gasket - if the engine is stock, the piston is .020 - .025 down in the hole. Combine that with a typical .040 composition head gasket and you've got an ugly quench (distance between the piston crown and head surface) number - and lower compression. Get the heads off and measure the piston deck height, and consider selecting a thinner gasket to get to around .045 quench.
You won't know the pushrod length until you mock up the assembly.
Finally, picking the right cam is all about the operating range of the engine, along with matching the capabilities of the head. What trans/diff ratio do you have?
Bolting together a bunch of parts without careful planning generally results in spending $$$ just to break parts or fail to achieve a real boost in performance.
To cam specs
Old Jun 29, 2009 | 01:11 PM
robC-1965's Avatar
robC-1965
This is exactly why these forums are so good - besides getting to know great people...........
Didn't know about needing self aligning rockers - will look up correct #
Another person I know said about using a thinner headgasket to increase combustion ratio
How can I find trans/diff ratio? It is a '78 L48 automatic
Old Jun 29, 2009 | 01:15 PM
robC-1965's Avatar
robC-1965
Ok - will go with the cloyles chain set -I quess the chain set would have less friction
Old Jun 29, 2009 | 06:55 PM
78IndyPace's Avatar
78IndyPace
Stock diff ratios for 78 with L48 and TH350 automatic were:
Standard - 3.08
High Altitude - 3.55 (cars delivered to +4,000' altitude)
My 78 has a bone stock L48 w/3.08 diff so I'm following your thread closely. I think Vortecs will be well suited to my driving - no racing, but really twisty mountain roads and some long trips.
Good luck!
Jerry
