79 auto trans. removal ?????
Old Jun 24, 2009 | 09:55 PM
speedreed8's Avatar
speedreed8
Default 79 auto trans. removal ?????
how do you hold the engine up, when removing the auto transmission.
is it ok to put a board under the oil pan with a jack, or do i need to get on the side edges of the pan?
Old Jun 24, 2009 | 10:25 PM
SH-60B's Avatar
SH-60B
I do it with the jackstand & board right in the center. The pan is pretty strong.
Old Jun 25, 2009 | 05:45 PM
speedreed8's Avatar
speedreed8
thanks.
Old Jun 25, 2009 | 06:15 PM
SH-60B's Avatar
SH-60B
If you find you need to tilt the engine/transmission assembly much to get at some bolts or whatever reason, remove the distributor so it doesn't hit the firewall.
To 79 auto trans. removal ?????
